IP Phone Number Display
Aug 6th, 2010
Hi All,
I have a requirement on Cisco Call Manager something like below scenarion.I am running CCM version 7.1.5
1. I am calling from my IP Phone to my Mobile.
2. When i call from IP Phone to my mobile i get display in my mobile as the number of IP Phone ( Incoming Number).
3. Is there any way where i can restrict the number of my ip phone to display on my mobile ?
Thanks & Regds,
Lalit
paolo bevilacqua Fri, 08/06/2010 - 06:52
  • Hall of Fame,
    Founding Member
Do you use ISDN PRI? Or analog lines ?
lalit@_78 Fri, 08/06/2010 - 06:54
Hi ,
I use PRI Lines on my Gateway. I just want to know whether this can be achieved through route pattern or the service parameter options.
Thanks & Regds,
Lalit
paolo bevilacqua Fri, 08/06/2010 - 06:58
  • Hall of Fame,
    Founding Member
Yes, add a route pattern with a prefix of your choice like *67#, configure so the prefix is discarded but calling party presentation restricted.
That will set a certain bit in ISDN Q931 so that calling number is restricted.
lalit@_78 Fri, 08/06/2010 - 07:06
Hi ,
We have put a route pattern with " Calling Line ID Presentation " Value as " Restricted " even then we are seeing complete directory number of source ip phone being displayed on the mobile phone.
Thanks & Regds,
Lalit
paolo bevilacqua Fri, 08/06/2010 - 07:24
  • Hall of Fame,
    Founding Member
On the gateway, take "debug isdn q931" with "term mon".
