asymmetric NAT issues
Answered Question
Aug 6th, 2010
I'm having problems accesing other networks off the ASA interfaces.  I can VPN in and access anything on the inside interface and beyond into the core.  When I try and access a DMZ server off the ASA i get errors about asymmetric NAT.  VPN client comes in as an address of 10.112.15.x.
Can anyone help?
I have attached some of the config.
show ip addrress:
GigabitEthernet0/0       outside               x.x.x.x   255.255.255.0   CONFIG
GigabitEthernet0/1       inside                 10.112.2.250    255.255.255.0   CONFIG
GigabitEthernet0/2.610   DMZ_External           10.112.7.254    255.255.255.0   CONFIG
GigabitEthernet0/2.620   DMZ_Internal           10.112.6.254    255.255.255.0   CONFIG
GigabitEthernet0/2.640   DMZ_Mgmt               10.112.10.254   255.255.255.0   CONFIG
Elements from config:
access-list nonat extended permit ip 10.112.0.0 255.240.0.0 10.112.7.0 255.255.255.0
access-list nonat extended permit ip 10.112.0.0 255.240.0.0 10.112.10.0 255.255.255.0
access-list nonat extended permit ip 10.112.0.0 255.240.0.0 10.112.6.0 255.255.255.0
access-list nonat extended permit ip 10.112.0.0 255.240.0.0 10.112.15.0 255.255.255.0
nat-control
global (outside) 1 interface
nat (inside) 0 access-list nonat
nat (inside) 1 10.112.0.0 255.240.0.0
route outside 0.0.0.0 0.0.0.0 x.x.x.x. 1
route inside 10.112.0.0 255.240.0.0 10.112.2.254 1
Any pointers on what i'm doing wrong?
Thanks.
Correct Answer by Nagaraja Thanthry about 6 years 11 months ago
The reason is because you do not have a nonat rule for the DMZ traffic.
access-list dmz_nonat permit 10.112.6.0 255.255.255.0
nat (dmz) 0 access-list dmz_nonat
This should fix your issue.
NT
Overall Rating: 5 (1 ratings)
Correct Answer
Nagaraja Thanthry Fri, 08/06/2010 - 07:12
  • Cisco Employee,
NT
