UCS 200 M2 HDD driver for VMWare 4.0
Aug 6th, 2010
  • Cisco Employee,
UCS C200 M2 is not detecting hard disk controller(lsi megaraid 9260-4i ) in VMware ESX 4.0. I appreciate, if you can share the driver location.
Gowdaman
Jason Aarons Wed, 05/04/2011 - 16:10
  • Bronze, 100 points or more
At boot time did you hit Control H to go into the LSI MegaRaid utility and run the Configuration Wizard and setup your Virtual Drives (RAID 1, Boot) ? After you do that you need to go into the BIOS and set the Boot Order #1 to BUS 0E Dev 00 PCI ?? Else it won't boot off that disk once you do get ESXi installed.
Daniel Laden Mon, 05/09/2011 - 11:03
  • Cisco Employee,
You mention that you have ESX 4.0.  Reviewing the Hardware and Software Interoperability Matrix document, the minimum release is 4.0 Update 1.  You may have already known this but just covering the bases.
http://www.cisco.com/en/US/docs/unified_computing/ucs/interoperability/matrix/r_hcl_C_rel1.31.pdf
C200 M2
LSI
MegaRAID
9260-4i
vSphere 4.0U1
Thank You,
Dan Laden
