Question about configuring a ASA 5510
southpaw34
I am in the process of setting up our 5510 to replace our current SonicWall at my place of work.  When looking at our SonicWall config I noticed that the IP addresses we have setup for our phone vendor to access the PBX systems at our various sites are set up with a begining IP range and end range which are static.  These addresses go any where from 2 to 5 addresses and when you configure them through the SonicWall it lets you set a begining range and ending range.  Looking through the ASDM console I dont see away to define a range of static addresses for servers.  Do I need to enter in every PBX seperatly or is there a way to define a range like 192.xxx.xxx.200 through 192.xxx.xxx.205.
Jon Marshall
You can use object-groups but it does depends on whether you can summarise the range eg.
object-group network PBX
network-object 192.xx.xx.200 255.255.255.252
network-object host 192.xx.xx.205
would cover 192.xx.xx.200 -> 205
then in an acl you would refer to it as -
access-list outside_in permit tcp object-group PBX eq
Jon
Jon Marshall
Jon
Thanks Jon, I was actually just looking into that and thought that was the way it sh
ould be done.
So if I had multiple PBX's I would create object groups then
