ACE WAF missing profiles
Answered Question
Aug 6th, 2010
Hi all,
I'm working on an ACE WAF in standalone mode and found a problem. The built-in profiles for PCI and pass are missing, so I can not apply any policies, since all the xss, sql-injection, command injection, and other signatures are not there. I have tried to upgrade the appliance from version 6.0.2 to 6.0.3 but is the same.
I have previously worked with a cluster of 1 manager and 2 gateways and worked fine.
Is there a way to activiate those signature or profiles?
Thanks a lot, any answer is highly appreciated!!
Fernando
Correct Answer by venkatkr about 6 years 10 months ago
HI Fernando,
I am not sure if you have found the answer for this. What you need is to have BaseConfigSigned_1-0_1.ppf
This is downloadable with every release. So you can get this from download page. Once download you need to upload.
To upload this do the following
Rules & Signature --- >           Update Base Configuration
Hope it fixes your issue. Do let me know.
Venky
Overall Rating: 5 (1 ratings)
Correct Answer
venkatkr Tue, 08/10/2010 - 09:48
  • Cisco Employee,
HI Fernando,
Venky
fermendo Wed, 08/11/2010 - 19:17
Hello Venky,
Thanks a lot for your answer. Yes that was the problem, the base configuration was not loaded, as you mentioned. But then found another problem, the Update Base Configuration button was missing too, so I was not able to upload the base config.
After verifying the files needed for the base configuration and other signature files that were missing, what fixed the problem was to delete the cluster created and generate a new one. I don't know if the first one was corrupted or something. Once with the new cluster the base config could be uploaded and worked fine.
Thanks a lot!!!
Fer
Related Content
