Ringing while on a call - CME 8
Aug 6th, 2010
Ok, I am very new to CME, we just converted over last night. Over all things went well, but I have a VERY strange issue. I have a user that while she is on a call, hears ringing on the line. Not actually her phone ringing, but the ring you would expect to hear after dialing an out side number. She has a 7940 with a 7914 side car and it doesnt seem to matter what line she is on. Both sides of the call can hear the ringing, but it will ring for ever so I dont think its actually dialing a number, just ringing... Any ideas?
Paolo Bevilacqua Fri, 08/06/2010 - 10:51
You mean ringback tones heard by both parties ?
Do you have analog lines, it may be call-waiting by telco ?
Try to find out under which conditions it occurs.
nbcsecurities Fri, 08/06/2010 - 10:56
Exactly, both sides can hear the ring back after the call is active and both parties are on the line. All the lines are on a PRI so no analog lines, and no special features running on the PRI. The T1 is comming on a vWIC... So far, it seems like only calls from out of state are having the issue. And only this one user...
Paolo Bevilacqua Fri, 08/06/2010 - 11:03
Never heard anything like that.
I would recommend you go onsite and investigate in person, often users report things than then are different from reality.
nbcsecurities Fri, 08/06/2010 - 11:07
Actually am on site, and was able to hear a call she had a chance to hear a call that was doing it.
