Aug 6th, 2010
Can 8GB modules be used in an MD9509?  If so, does it also host the lastest supervisor card that support addional throughput?
bfeeny Fri, 08/06/2010 - 21:43
From the documentation:
"In addition to supporting Generation 2 modules, the Cisco MDS 9500 Series Switches and the Cisco MDS 9222i Switch support another set of modules called Generation 3 modules. Similar to Generation 2, each Generation 3 module can have one or more ports in port groups that share common resources such as bandwidth and buffer credits.
Generation 3 Fibre Channel modules are supported on the Cisco MDS 9506 and 9509 switches with Supervisor-2 modules, and on the MDS 9513 Director with Fabric 2 modules. The MDS 9222i switch supports the 4/44-port Host-Optimized Fibre Channel Switching module. MDS NX-OS Release 4.1(1) is required to support the Generation 3 modules."
The 8GB modules are Generation 3 modules.
Related Content
Trending Topics: Storage Networking
