Device sensed, but collection failed
Answered Question
Aug 6th, 2010
Attempting to gather the inventory information for a couple of Cisco Catalyst 2950G 48 EI Switches. Ciscoworks had problem gathering information from one of my switches. I checked if there's any differences in configuration, routing, or IOS versions. No differences except for management IP address.
Inventory collection job reported "Device sensed, but collection failed".
Attached is the IC_Server.log for the attempted job.
Correct Answer by Joe Clarke about 6 years 10 months ago
That is the problem.  Due to a bug in the ENTITY-MIB on 2950s, they must running 12.1(11)EA1 or higher in order for RME to fetch the inventory.
Overall Rating: 5 (1 ratings)
Joe Clarke Fri, 08/06/2010 - 17:18
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
What version of code is this switch running?
Correct Answer
Joe Clarke Mon, 08/09/2010 - 21:54
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
gassolini Mon, 10/11/2010 - 05:35
is there any patch or workaround for this problem?
Our customer can not upgrade the firmware on the devices.
Info about devices:
########DEVICE1################################
WS-C4006 Software, Version NmpSW: 6.2(1)
Copyright (c) 1995-2001 by Cisco Systems, Inc.
NMP S/W compiled on Apr 11 2001, 18:10:53
GSP S/W compiled on Apr 11 2001, 15:57:20
System Bootstrap Version: 5.4(1)
Hardware Version: 1.2  Model: WS-C4006  Serial #: JAB044301U8
Mod Port Model      Serial #              Versions
1   2    WS-X4013   JAB044301U8          Hw : 1.2
                                         Gsp: 6.2(1.0)
                                         Nmp: 6.2(1)
2   48   WS-X4148-RJ JAE04251J18          Hw : 2.3
3   48   WS-X4148-RJ JAE0433029Y          Hw : 2.3
4   48   WS-X4148-RJ JAE043302M7          Hw : 2.3
########DEVICE2################################
Cisco Application Control Software (ACSW)
TAC support: http://www.cisco.com/tac
Copyright (c) 2002-2009, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained herein are owned by
other third parties and are used and distributed under license.
Some parts of this software are covered under the GNU Public
License. A copy of the license is available at
http://www.gnu.org/licenses/gpl.html.
  loader:    Version 12.2[120]
  system:    Version A2(2.3) [build 3.0(0)A2(2.3)]
  system image file: [LCP] disk0:c6ace-t1k9-mz.A2_2_3.bin
  installed license: ACE-08G-LIC ACE-SEC-LIC-K9
Software
Sandro
Joe Clarke Mon, 10/11/2010 - 07:52
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Please start a new thread for your issue.
