WAE 512 or WAVE 574
Answered Question
Aug 6th, 2010
Which one it the better choice...?
Correct Answer by Eric Rose about 6 years 11 months ago
I am not sure what the point is...?? That document is a little dated. According to the caveat section it is based on 4.0.3 release.
http://www.cisco.com/en/US/docs/solutions/Enterprise/Data_Center/WAASDC11.html#wp102380
Eric Rose
Overall Rating: 5 (1 ratings)
wrobbin Fri, 08/06/2010 - 13:07
WAE--512#sh tfo detail
   Policy Engine Config Item            Value
   State                                Registered
   Default Action                       Use Policy
   Connection Limit                     1500
   Effective Limit                      1490
   Keepalive timeout                    3.0 seconds
WAE--512#
NO-HOSTNAME#sh tfo detail
   State                                Registered
   Connection Limit                     1300
   Effective Limit                      1300
NO-HOSTNAME#
But i wonder is the 512 gonna be around for awhile ...
Eric Rose Mon, 08/09/2010 - 07:05
  • Cisco Employee,
The WAVE-574 is a newer model and it also has the Virtual Blade support.
Thanks.
Eric Rose
wrobbin Mon, 08/09/2010 - 07:12
Yes but we dont ever plan on using the Virtual Blade...The 512's are 850 bucks cheaper to us and offer 190 more TFO connections then the 574..What i wanted to make sure before i deploy is that Cisco isnt gonna axe these anytime soon...
Eric Rose Mon, 08/09/2010 - 07:20
  • Cisco Employee,
From the 4.2.1 sizing guidelines. The 574 supports more connections.
The 512 with 2GB of RAM support 1200 connections
The 574 with 6GB of RAM support 1300 connections
Your screen capture is that on the same version of software?
wrobbin Mon, 08/09/2010 - 07:41
yup all 4.1.5f..
OE512
WAE-X-512#sh tfo detail
   State                                Registered
WAE-X-512#sh inventory
PID: WAE-512-K9 VID: 0
WAE-X-512#
WAE-X-512#sh ver
Cisco Wide Area Application Services Software (WAAS)
Copyright (c) 1999-2010 by Cisco Systems, Inc.
Cisco Wide Area Application Services Software Release 4.1.5f (build b2 Apr 20 2010)
Version: oe512-4.1.5f.2
Compiled 12:26:34 Apr 20 2010 by cnbuild
System was restarted on Sat Jun  5 21:50:52 2010.
The system has been up for 9 weeks, 1 day, 12 hours, 50 minutes, 3 seconds.
WAE-X-512#
Now if upgrading to 4.2.1 will bring my connections down to 1200 that’s unacceptable
Eric Rose Mon, 08/09/2010 - 07:46
  • Cisco Employee,
Ok the sizing guide from 4.1.5 also shows 1200 and 1300 for connection limits. I am not sure about the output
Will have to let somebody from the BU/Support comment.
Thanks.
wrobbin Mon, 08/09/2010 - 07:47
In the
Ordering Guide for Cisco WAAS dated
June 11, 2010
its says
WAE-512-K9
TCP connections
TCP connections
750 - 1500
Cisco WAE-512 with chassis with 1 GB SDRAM, 1
250-GB HDD, and AC power supply
Additional memory and HDDs available for higher
optimized TCP connection count and RAID-1
redundancy; virtual blades are not supported
US$12,500
wrobbin Mon, 08/09/2010 - 08:13
Page 5 of 5..
When the Application Optimizers are disabled the maximum TCP connections for the following platform is as
follow: NME 502 - 500 , NME 522 - 800, 512-1GB - 750, 512-3G - 1500, 612-2G - 2000, 612-4G - 6000.
What does that really mean ?
WAE-X-512#sh accelerator
Accelerator     Licensed        Config State    Operational State
cifs            Yes             Enabled         Running
epm             Yes             Enabled         Running
http            Yes             Enabled         Running
mapi            Yes             Enabled         Running
nfs             Yes             Enabled         Running
ssl             Yes             Enabled         Running
video           No              Enabled         Shutdown
wafs-core       Yes             Disabled        Shutdown
wafs-edge       Yes             Disabled        Shutdown
WAE-X-512#
Eric Rose Mon, 08/09/2010 - 09:01
  • Cisco Employee,
My guess would be when transport license is used and/or when all AO are disabled.
wrobbin Mon, 08/09/2010 - 14:01
http://www.cisco.com/en/US/docs/solutions/Enterprise/Data_Center/WAASDC11.html#wp80841
Device
Max Optimized TCP Connections
Max CIFS Sessions
Single Drive Capacity [GB]
Max Drives
RAM [GB]
Max Recommended WAN Link [Mbps]
Max Optimized Throughput [Mbps]
Max Core Fan-out [Peers]
CM Scalability [Devices]
NME-WAE-302
250
N/A
80
NME-WAE-502
500
500
120
WAE-512-1
750
750
250
100
WAE-512-2
1500
1500
250
150
WAE-612-2
2000
2000
300
250
30
2000
WAE-612-4
6000
2500
300
350
50
2500
WAE-7326
7500
2500
300
6
450
96
wrobbin Tue, 08/10/2010 - 05:02
Eric,
        The point being i need to order a good amount of these for the company i work for..and i would like to get the most bang for buck with  850 dollar difference between them once i get to around 13-15 that 850 dollars adds up the where i could have got an additonal one...with a 512 vs a 574..
wrobbin Tue, 08/10/2010 - 10:36
Just learned Cisco was is doing an EOS on this product but thank you for the help Eric
