WLC Upgrade and Backup
Aug 6th, 2010
Hello;
Can anyone ponit me in the right direction as to the following;
1. I need to backup the running-config from the WLC but i cannot find how to see what the name of the file is on the WLC. Its Version 6.x
2. When I upgrade to Version 7.x from 6.x do I need to upgrade both the flash and the bootloader?  Where can I find both these files?
JRB
Kayle Miller Fri, 08/06/2010 - 13:45
  • Silver, 250 points or more
Joel,
     - From the controller click on Managment> Upload>
     - From the Upload from controller option select Configuration and fill out the TFTP information and the desired path and filename. Then click start
     - You will need to have either valid warranty or a support contract with Cisco, if so follow these instructions.
     - http://www.cisco.com Click on Support
     -  Click on Download Software, Then Wireless, Then Wireless Lan Controllers, Then select your type of controller and there you will find the firmware files you need. (you maybe prompted at any point in this sequence to login.)
Hope this helps.. Please rate useful posts.
Kayle
Trending Topics - Security & Network
