How can I do a factory reset to my DMS 5.1
Answered Question
Aug 6th, 2010
Hi guys!:
I have a DMS 5.1 for demo and each time you do a demo you make different configurations to the devices. Is there a way to do a factory reset to DMM and Video Portal instead to remember each change that you made? I really appreciate your help! Thank you!
Correct Answer by Tomas De Leon about 6 years 6 months ago
Karla,
I am sorry.  I spoke out of place. The VMware images are to be used for
internal use only.  VMware images cannot be upgraded.  You must have
the VMware install disks for each DMS version.
So it looks like a fresh install will be need each time you want to do
a Demo for a different customer or simply delete what you configured
for prior customer or set a template demo to use for all customers..
If you need to get the iso image for 5.1 to perform fresh installs, please
contact your local Cisco sales team or Account representative.
T.
Overall Rating: 5 (1 ratings)
Tomas De Leon Fri, 08/06/2010 - 16:07
Sorry, no magical button...
It is called Re-Install the DMM & CVP images from DVD.  The problem
with this is make sure you have your License File backup to re apply each
time...
Another solution for DEMOs is use the VMware Images for DMM & CVP.
Since this is a DEMO and not production, you should be able to do everything
you need.   This way you will have the VIRTUAL appliances from either the
install point or a BASE Template.   Save the VM disks in a safe place and
then use each time you need to setup a DMM.
This may work better for DEMOs...
Cheers!
T.
Karla Lopez Mon, 08/09/2010 - 14:34
Hi!:
Thank you for your answer. Do you know from where I can download a VM with DMS 5.2? If I try to install DMS 5.1 (to do the upgrade to 5.2 later because I just have DMS 5.1 bootable) in VM, the installer says that is not a valid hardware and stops the intallation. So, is there a way to download a VM in DMS 5.2?? Thank you in advance!
Karla
Correct Answer
Tomas De Leon Mon, 08/09/2010 - 19:51
Karla,
T.
