RV120W - Performance and speed, kill session
Aug 6th, 2010
I have problem about performance or speed with the RV120W VPN router. I have change the Hardware, (same with the same firmware) is the same problem. When I have a Remotedesktop session, he says, that the  connection break.
I have change th hardware to a Linksys router, with this hardware works it fine. I have a QSC Sync 2MB cable.
Have any other the same problem ?
vragotha Fri, 08/06/2010 - 23:50
  Are you trying to RDP to a device behind the router? Can you post the error it lists for the disconnect reason? Have you tried using VNC to see if it works instead of RDP?
streaves Fri, 08/13/2010 - 15:59
Hi Michael -- Please see my post on your other thread. Will you please help us troubleshoot by sharing your configuration file?
Stephanie Reaves
Small Business Technology Group
