How resolve dialpeer problem
Aug 7th, 2010
i have a vic-2did, and my background information like the topic :
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a008010ff92.shtml
and i have 3 did lines.
and i had config voice port in immediate start:
I had get "823T", need convert 8023, so i had configurated:
voice translation-rule 10
rule 1 /^8\(..\)/ /80\1/
voice translation-profile DID_Convert
translate called 10
voice-port 0/1/0
signal did immediate
translation-profile incoming DID_Convert
cptone HK
timing delay-start 400
But Dial-peer match result is "Result=NO_MATCH"
i had get new "debug dialpeer inout" result:
cr0.chhkg#
*Aug  7 17:50:40 CST: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=, Called Number=, Voice-Interface=0x6443DF50,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Result=NO_MATCH(-1) After All Match Rules Attempt
*Aug  7 17:50:41 CST: //-1/1244451480E5/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=8, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=8
   Result=Partial Matches(1) after DP_MATCH_DEST
*Aug  7 17:50:41 CST: //-1/1244451480E5/DPM/dpMatchPeersMoreArg:
   Result=MORE_DIGITS_NEEDED(1)
   Calling Number=, Called Number=82, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=82
   Calling Number=, Called Number=823, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=823
*Aug  7 17:50:51 CST: //-1/1244451480E5/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=823T, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=823T
   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
*Aug  7 17:50:51 CST: //-1/1244451480E5/DPM/dpMatchPeersMoreArg:
   Result=NO_MATCH(-1)
What can i do next?
