WCS not able to monitor 1142 AP
Aug 7th, 2010
I am running a WCS 6.0.181.0 with WiSM on a 6509 series switch. the problem is that the WCS is not able to generate heat map for the access points installed on a remote site. th AP mode is local. the WLC on the WCS are in a reachable state. I can see the access points on the WCS but the antenna are specified as other and i cannot generate the RF frequency on the maps.
for the release note of this WCS version is stating that both the WiSM and the access points are supported.
Please check the error i am having on the WCS and the release note for the WCS version
I highly appreciate your cooperation
Elie
Pari Thiagasundaram Tue, 08/10/2010 - 10:43
What happens when you do a "Recompute RF prediction".?
I would also suggest you be on the WCS 7.0 if that is an option.
