I dont know if this is the right place but Failover
Aug 7th, 2010
I have 2 ASA 5520's set
up in Active Passive failover. All the ports have ip's as required and all the ports are b
eing monitored. Question.. If it failes to the second firewall will all the same port IP's a
nd access to vlans be the same?
also access to the managment network?
ufuk guler Sat, 08/07/2010 - 13:33
Hello Perry,
                If your primary firewall fails, secondary firewall will undertake all active configurations. That means secondary firewall works with existing ip addresses which are assigned to primary firewall.
Ufuk Guler
Magnus Mortensen Sat, 08/14/2010 - 19:39
  • Cisco Employee,
Perry, to follow up with what Ufuk said, if a failover occurs, the 'now active' firewall will start using the active IPs and MACs. The firewall will then send out a gratuitous arp so that all the switches know that the active MAC now resides on the port connected to the 'now active' firewall. The failover should be seamless to the end users.   - Magnus
Posted from my mobile device.
