2950 12 Port Metro Ethernet Multiple Vlans
Aug 7th, 2010
Hello All,
     I have a client that shares office space and also wants to share a colocation.  Client 1 currently has a 10MB Metro Circuit between the office and the colocation using 2 Cisco 2950 switches.  The CIsco switches are configured with a vlan beween port 1 respectively and port 2 goes to the LAN both in the colocation and office.
All works great.
The chalenge is to add Client 2 completely seperate than Client 1.  I am wondering if there is a way configure port 2 on both switch in a seperate vlan or segment vlan 1?
The 2 swicthes configuration are identical.
vtp domain Client1
vtp mode transparent
spanning-tree optimize bpdu transmission
vlan 3875
name Metro-E
int f0/1
description MetroE to Colo
switchport access vlan 3875
switchport trunk allowed vlan 3875
switchport mode trunk
switchport nonegotiate
speed 100
duplex full
spanning-tree bpdufilter enable
no shut
interface FastEthernet0/2
description Office Link
no shut
line con 0
Below was my first attempt but with testing interface 2 and 3 where able to see each other.
int f/03
no shut
Any and all help would be appreciated.
Giuseppe Larosa Sat, 08/07/2010 - 12:16
  • Hall of Fame,
    Founding Member
Hello Gregory,
you simply need to create a second vlan for example 3876 you need to do it on both switches and to allow it on trunk both sides
conf t
vlan 3876
name customer2
exit
int fas0/1
switchport trunk allowed vlan add 3876
int fas0/3
switchport
switchport mode access
switchport access vlan 3876
note the add keyword without it you miss vlan 3875 !
Hope to help
Giuseppe
hotsparez Sat, 08/07/2010 - 12:45
Thank you giuslar
SO what your saying a single port can be part of 2 VLANs and also be segregated from each other.  I will attempt this afternoon and will update ASAP.
Thanks again.
Related Content
