ASA 5505 VPN client can't ping inside LAN
Aug 7th, 2010
Hello everyone,
I tried to search for an answer to this question but I couldn't find the answer. So here it goes:
I configured the VPN on the ASA, I can get a client to connect to the ASA just fine, however I can't ping any interfaces on the ASA or on the inside LAN. I'm giving VPN clients IP's of 192.168.60.x/24 and the inside network is 192.168.1.x/24. I got this to work the last time I configured an ASA but I forgot all the things I did. I'm sure it's something small. Any help is greatly appreciated.
ASA Version 7.2(4)
hostname max
domain-name default.domain.invalid
enable password xxxxxxx encrypted
passwd xxxxx encrypted
names
name 192.168.1.3 Xbox description IP address for Xbox
interface Vlan1
description Default internal vlan on max
nameif inside
security-level 100
ospf cost 10
interface Vlan2
description Internet vlan on max
nameif Internet
security-level 0
ip address dhcp setroute
ospf cost 10
interface Vlan3
description DMZ vlan on max
no forward interface Vlan1
nameif DMZ
security-level 50
ip address 10.100.100.1 255.0.0.0
ospf cost 10
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
switchport access vlan 3
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
clock timezone EST -5
clock summer-time EDT recurring
dns server-group DefaultDNS
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
object-group service Xbox_port tcp-udp
description TCP-UDP 3074
port-object eq 3074
object-group service Xbox_port_2 udp
description UDP port 88
port-object eq 88
object-group network Internal_Networks
network-object 10.0.0.0 255.255.255.0
network-object 10.1.0.0 255.255.255.0
network-object 172.16.0.0 255.255.255.0
network-object 10.20.0.0 255.255.255.0
network-object 10.30.0.0 255.255.255.0
access-list Internet_access_in extended permit udp any interface Internet eq 3074 inactive
access-list Internet_access_in extended permit tcp any interface Internet eq 3074 inactive
access-list Internet_access_in extended permit udp any interface Internet eq 88 inactive
access-list inside_access_in extended permit ip any any
access-list acl-outside extended permit icmp any any echo-reply
access-list acl-outside extended permit icmp any any unreachable
access-list acl-outside extended permit icmp any any traceroute
access-list acl-outside extended permit icmp any any time-exceeded
access-list nonat extended permit ip 192.168.1.0 255.255.255.0 object-group Internal_Networks
access-list nonat extended permit ip any 192.168.60.0 255.255.255.240
access-list Split_Tunnel_List remark The network behind the ASA
access-list Split_Tunnel_List standard permit 192.168.1.0 255.255.255.0
pager lines 24
logging enable
logging buffer-size 10000
logging buffered critical
logging asdm informational
logging debug-trace
mtu inside 1500
mtu Internet 1500
mtu DMZ 1500
ip local pool VPN_Client_IP_Pool 192.168.60.2-192.168.60.11 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
icmp permit any inside
icmp deny any Internet
asdm image disk0:/asdm-524.bin
no asdm history enable
arp timeout 14400
global (Internet) 1 interface
nat (inside) 0 access-list nonat
nat (inside) 1 192.168.1.0 255.255.255.0
access-group inside_access_in in interface inside
access-group acl-outside in interface Internet
router ospf 1
router-id 192.168.1.1
network 192.168.1.0 255.255.255.0 area 0
log-adj-changes
redistribute static subnets
default-information originate
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
aaa authentication enable console LOCAL
aaa authentication ssh console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map Internet_dyn_map 20 set pfs group1
crypto dynamic-map Internet_dyn_map 20 set transform-set ESP-3DES-SHA
crypto map Internet_map 65535 ipsec-isakmp dynamic Internet_dyn_map
crypto map Internet_map interface Internet
crypto isakmp enable Internet
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 inside
ssh 76.10.192.197 255.255.255.255 Internet
ssh timeout 30
console timeout 0
dhcpd auto_config Internet
dhcpd address 192.168.1.2-192.168.1.33 inside
dhcpd enable inside
tftp-server inside 192.168.1.2 /asaconfig
group-policy darin.personal internal
group-policy xxxxxx attributes
vpn-tunnel-protocol IPSec
split-tunnel-policy tunnelspecified
split-tunnel-network-list value Split_Tunnel_List
default-domain value default.domain.invalid
username xxxxx password xxxxxxx encrypted privilege 0
username xxxxxx attributes
vpn-group-policy xxxxxx
username xxxxx password xxxxxxx encrypted privilege 15
tunnel-group xxxxxx type ipsec-ra
tunnel-group xxxxxx general-attributes
address-pool VPN_Client_IP_Pool
default-group-policy xxxxxxxx
tunnel-group xxxxxxxxx ipsec-attributes
pre-shared-key *
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
service-policy global_policy global
prompt hostname context
: end
ufuk guler Sat, 08/07/2010 - 11:33
Hello Darin,
               Could you add below line to your outside acl and test again. Hope it can help you.
Ufuk Guler
darin.miller Sat, 08/07/2010 - 11:53
I added the line but it didn't help. Besides, I don't want to enable ping for the entire outside interface but full access to the inside network. I'm beginning to think that I need to set my ASA as the default gateway for VPN clients. It's not defined when I connect.
ufuk guler Sat, 08/07/2010 - 12:12
Hi Darin,
         Could you enable icmp inspection and try it again. Just add "inspect icmp" command under "class inspection_default" section. At the same time i think that you are able to access local resource via vpn, except icmp. isn't it?
     inspect icmp
Ufuk Guler
darin.miller Sat, 08/07/2010 - 18:17
Nope I can't access any inside resources through the VPN at all. Ping, telnet, ssh, nothing. I'm thinking I might need a NAT statement in there somewhere.
Nagaraja Thanthry Sat, 08/07/2010 - 18:30
  • Cisco Employee,
Can you please post the latest configuration here (x out all the public IP addresses).
NT
darin.miller Sat, 08/07/2010 - 19:13
ASA Version 7.2(4)
hostname max
enable password xxxx encrypted
passwd xxxx encrypted
names
interface Vlan1
nameif inside
security-level 100
ospf cost 10
interface Vlan2
nameif Internet
security-level 0
ospf cost 10
interface Vlan3
nameif DMZ
security-level 50
ospf cost 10
banner exec You are logged into Max's firewall
banner login Max's firewall
ftp mode passive
protocol-object udp
protocol-object tcp
port-object eq 3074
port-object eq 88
access-list nonat-in extended permit ip 192.168.1.0 255.255.255.0 object-group Internal_Networks
pager lines 24
logging enable
logging debug-trace
mtu inside 1500
mtu Internet 1500
mtu DMZ 1500
arp timeout 14400
nat (inside) 0 access-list nonat-in
router ospf 1
log-adj-changes
http server enable
encryption 3des
hash sha
group 2
lifetime 86400
telnet 0.0.0.0 0.0.0.0 inside
telnet timeout 5
ssh x.x.x.x 255.255.255.255 Internet
ssh timeout 30
console timeout 0
dhcpd enable inside
group-policy darin.personal attributes
split-tunnel-network-list none
username darin.miller password xxxx encrypted privilege 0
username darin.miller attributes
vpn-group-policy darin.personal
username darin password xxxx encrypted privilege 15
tunnel-group darin.personal type ipsec-ra
tunnel-group darin.personal general-attributes
default-group-policy darin.personal
tunnel-group darin.personal ipsec-attributes
pre-shared-key *
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
Cryptochecksum:xxxx
: end
Nagaraja Thanthry Sat, 08/07/2010 - 19:22
  • Cisco Employee,
You are correct. The nonat rule is incorrect. Please add the following
lines:
access-list nonat-in extended permit ip object-group Internal_Networks 192.168.60.0 255.255.255.0
access-list nonat-in extended permit ip 192.168.1.0 255.255.255.0 192.168.60.0 255.255.255.0
management-access inside
Hope this helps.
NT
Message was edited by: Nagaraja Thanthry
darin.miller Sun, 08/08/2010 - 20:58
Nope, didn't work. I was able to connect, and this time my VPN-client's ipconfig listed 192.168.60.1 as the default gateway.
darin.miller Mon, 08/09/2010 - 01:13
What I need is to be able to have my home LAN (192.168.1.0/24) the Secured Route and everything else goes through my local LAN.
darin.miller Mon, 08/09/2010 - 03:37
I reset everything to the original way I had it and ran a packet trace:
max# pac input internet icmp 192.168.60.2 0 8 192.168.1.2 det
Phase: 1
Type: CP-PUNT
Subtype: l2-selective
Result: ALLOW
Config:
Additional Information:
Forward Flow based lookup yields rule:
in  id=0x39d6bf8, priority=12, domain=punt, deny=false
        hits=12667, user_data=0x4299570, cs_id=0x0, l3_type=0x8
        src mac=0000.0000.0000, mask=0000.0000.0000
        dst mac=0000.0000.0000, mask=0000.0000.0000
Phase: 2
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
in  id=0x39f1fa0, priority=1, domain=permit, deny=false
        hits=6376931, user_data=0x0, cs_id=0x0, l3_type=0x8
Phase: 3
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Found no matching flow, creating a new flow
Phase: 4
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   192.168.1.0     255.255.255.0   inside
Phase: 5
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
in  id=0x3a793e8, priority=12, domain=permit, deny=false
        hits=6, user_data=0x3a78038, cs_id=0x0, flags=0x0, protocol=1
        src ip=0.0.0.0, mask=0.0.0.0, port=0
        dst ip=0.0.0.0, mask=0.0.0.0, port=0, dscp=0x0
Phase: 6
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
in  id=0x39f4828, priority=0, domain=permit-ip-option, deny=true
        hits=12341, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 7
Type: CP-PUNT
Subtype:
Result: ALLOW
Config:
in  id=0x42a06e0, priority=79, domain=punt, deny=true
        hits=9, user_data=0x3637180, cs_id=0x0, flags=0x0, protocol=0
        src ip=192.168.60.2, mask=255.255.255.255, port=0
Phase: 8
Type: VPN
Subtype: ipsec-tunnel-flow
Result: ALLOW
Config:
in  id=0x3a6f5d8, priority=69, domain=ipsec-tunnel-flow, deny=false
        hits=9, user_data=0x7d1d6c, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 9
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
in  id=0x39f3ba0, priority=66, domain=inspect-icmp-error, deny=false
        hits=75, user_data=0x39f3ad0, cs_id=0x0, use_real_addr, flags=0x0, protocol=1
Phase: 10
Type: HOST-LIMIT
Subtype:
Result: ALLOW
Config:
in  id=0x41892e0, priority=0, domain=host-limit, deny=false
        hits=55, user_data=0x0, cs_id=0x0, flags=0x0, protocol=0
Phase: 11
Type: NAT
Subtype: rpf-check
Result: DROP
Config:
  match ip inside 192.168.1.0 255.255.255.0 Internet any
    dynamic translation to pool 1 (75.187.60.114 [Interface PAT])
    translate_hits = 46, untranslate_hits = 1
out id=0x4256e30, priority=1, domain=nat-reverse, deny=false
        hits=53, user_data=0x4256c90, cs_id=0x0, flags=0x0, protocol=0
        dst ip=192.168.1.0, mask=255.255.255.0, port=0, dscp=0x0
Result:
input-interface: Internet
input-status: up
input-line-status: up
output-interface: inside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
darin.miller Mon, 08/09/2010 - 13:49
OK check this out. I got my hands on a previous config I did for a customer. I found out that IT WAS a NAT statement that was missing, so I added these 3 statements:
nat (inside) 0 access-list LAN_nat0_outbound
access-list LAN_nat0_outbound extended permit ip any 192.168.60.0 255.255.255.0
access-list LAN_nat0_outbound extended permit ip any 192.168.0.0 255.255.255.0
So, now VPN clients can ping the 192.168.1.0/24 internal network and vice versa, but VPN clients still can't telnet into devices in the 192.168.1.0/24 subnet. I'm guessing PAT is needed but where?
