OSPF Stub Area setup
Answered Question
Aug 7th, 2010
I'm setting up a stub area with 2 routers over a switch. I'm having a  problem with getting the adjacency through the switch, but I get it if I  use a crossover cable.
Besides the ports being active on the switch is there any other configuration that I need? i.e. a VLAN?
Correct Answer by Nagaraja Thanthry about 6 years 10 months ago
Please make sure that both ports where you have connected the routers are on
the same VLAN (same broadcast domain). Also, make sure that the switch
supports multicast traffic.
Hope this helps.
NT
Overall Rating: 5 (1 ratings)
Correct Answer
Nagaraja Thanthry Sat, 08/07/2010 - 15:10
  • Cisco Employee,
Hope this helps.
NT
