How can we disable or di-activate the "Hold Key" feature from Cisco 7970 IP Phone Model ?
Answered Question
Aug 8th, 2010
How can be Disable the Hold Key feature from Cisco IP Phone 7970 Model .
Correct Answer by Aaron Harrison about 6 years 6 months ago
You can try creating a new softkey set and assigning it to the phones.. assuming a linux CCM:
- First go to Device/Device Settings/Softkey Template
- Copy the current softkey set, give it a new name and save it
- Towards the top right there is a 'Configure Softkey Layout' link; hit 'Go' on that
- Select the 'Connected' state, then move the 'Hold' key out of the 'Selected' softkey box
- You may want to do the same for the other 'Connected...' states
Then assign that template to the phones.
Aaron
Please rate helpful posts...
Overall Rating: 5 (1 ratings)
Correct Answer
Aaron Harrison Sun, 08/08/2010 - 14:20
Aaron
Syed Akbar Ali Mon, 08/09/2010 - 00:36
Aaron
Thanks for your feedback, its Helps for me .
I am high appreciated.
Syed Akbar Ali
