Unity calls home number for notification and asks for ID
Answered Question
Hi there
I finally setup unity to call a number for notification.
It calls correct and the prompts for the ID (please enter your ID or press "1" to disable notifications on this line), but no matter what I enter (tried PIN with and without # or directory number), it continious asks for the ID and hangs up after a while.
Am I missing something?
Andre
Correct Answer by Bradford Magnani about 6 years 7 months ago
Hi Andre,
Sounds like DTMF may not be making it to Unity.  Take a quick look at this document explaining a dial-peer configuration that you may need to adjust on your GW:
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_tech_note09186a0080094607.shtml
Hope that helps,
Brad
Overall Rating: 5 (1 ratings)
