pleas frind i need help in switch 2900XL
hi frind
I need help . i have cisco switch 2900 XL , I install new image , but when it reload , this appear for me
flashfs[1]: Initialization complete.
...done Initializing C2900XL flash.
C2900XL POST: System Board Test: Passed
C2900XL POST: Daughter Card Test: Passed
C2900XL POST: CPU Buffer Test: Passed
C2900XL POST: CPU Notify RAM Test: Passed
C2900XL POST: CPU Interface Test: Passed
C2900XL POST: Testing Switch Core: Passed
C2900XL POST: Testing Buffer Table: Passed
C2900XL POST: Data Buffer Test: Passed
C2900XL POST: Configuring Switch Parameters: Passed
C2900XL POST: Ethernet Controller Test: Passed
C2900XL POST: MII Test: Passed
cisco WS-C2924-XL (PowerPC403GA) processor (revision 0x11) with 8192K/1024K byte
s of memory.
IOS (tm) C2900XL Software (C2900XL-C3H2L9S-M), Version 12.0(5)WC17, RELEASE SOFT
WARE (fc1)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Tue 13-Feb-07 15:28 by antonino
00:00:31: %IMAGE_MISMATCH-3-MALIBU_IMAGE_MISMATCH:
LRE firmware not supported by switch hardware.
Please download a non-LRE image.
what is that , and what is the correct imag (.bin) to install in it
regards ...
25 Replies 25
Nagaraja Thanthry
What is the image (full image name) you are trying to load to the switch?
You should be using c2900xl-c3h2s-mz.120-5.WC17.bin. I guess you might have
downloaded c2900xl-c3h2l9s-mz.120-5.WC17.bin which is for LRE switches.
Hope this helps.
NT
dear frind ...
I am very grateful  for you're help , yes i downloaded this image (c2900xl-c3h2l9s-mz.120-5.WC17.bin) ,
so i will tray to download the new image ,
hint
can you tell me how i can know the correct image i must download
regards
You should look for C2900 IOS image (without keyword LRE). Here is the link
for the latest image:
http://tinyurl.com/2dnsvy8
Hope this helps.
NT
Dear
when i inter u'r link this appear for me
no item found
can help me
regards ..
Please try this link:
http://tinyurl.com/5fj9e8
NT
ok dear
i am very grateful for u'r response , can u tell me which file from this site i choice
thank you
c2900xl-c3h2s-mz.120-5.WC17.bin should work.
NT
ok dear ..
i will try and tell u
regards
Nagaraja Thanthry
To add to my earlier post, c2900xl-c3h2l9s-mz.120-5.WC17.bin is C2900XL LRE
IOS IMAGE where as you need C2900 IOS IMAGE (if you are downloading it from
Cisco Site, it is 3rd one from the top I believe).
Hope this helps.
NT
dear i downlad this image
but this error apear
Initializing C2900XL flash...
flashfs[1]: 2 files, 1 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 3612672
flashfs[1]: Bytes used: 1933312
flashfs[1]: Bytes available: 1679360
flashfs[1]: flashfs fsck took 6 seconds.
s of memory.
Processor board ID FAB0345Y0N9, with hardware revision 0x01
Last reset from warm-reset
Processor is running Enterprise Edition Software
Cluster command switch capable
Cluster member switch capable
24 FastEthernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:30:94:63:0B:C0
Motherboard assembly number: 73-3382-07
Power supply part number: 34-0834-01
Motherboard serial number: FAB034466K0
Power supply serial number: DAB03352M83
Model revision number: A0
Model number: WS-C2924-XL-A
System serial number: FAB0345Y0N9
Press RETURN to get started!
C2900XL INIT: Complete
00:00:21: %LRE_UPGRADE-4-INIT_RESOURCE: cannot locate lre firmware files
00:00:29: %SYS-5-CONFIG: Configured from NVRAM by console
00:00:31: %SYS-5-RESTART: System restarted --
WARE (fc1)
where the problem
regards ..
The image you downloaded has "l9" which means it is for LRE platform. Download the image that does not have "l9" in its name.
NT
dear all
i install new image in the problem still the same , please frind where the problem , i realy need help
thank you ...
what is happen no buddy can help me
to resolve my problem ???????
   You should only be using this image .  c2900xl-c3h2s-mz.120-5.WC17.bin .    Verify  this image is in flash. Do a dir flash:  .  Did you set your boot statement once you downloaded the image ?    "boot system flash:c2900xl-c3h2s-mz.120-5.WC17.bin .  Then do a write mem  command and reload.
