Low Virtual Memory Alert starts every 60-70 days
Aug 8th, 2010
We have a Cluster with a Pub and 4 Subs. Every 60-70 days, we start getting a low virtual memeory alert on the Publisher.
The threshold is set to 30% on RTMT (which means that when Virtual memory becomes less than 30%, RTMT will start alerting). We have to reboot the Publisher to get rid of this alert.
CUCM version is 6.1.3.3190-1 .
The Publisher server stats are -
HW Platform       : 7835H
Processors        : 1
Type              : Intel(R) Xeon(TM) CPU 3.40GHz
CPU Speed         : 3400
Memory            : 2048 MBytes
Is there any Bug associated with this CUCM version that could be causing some kind of a memory leak?
There are 2300 phones in the cluster and none is registered to the Publisher.
Kumar Vishal Sun, 08/08/2010 - 15:06
The alert looks like -
Machine Name: CCM-PUB
Severity: Critical
App ID: Cisco AMC Service
Message: : 1310: Aug 05 22:11:31.261 UTC : %CCM_RTMT-RTMT-2-RTMT-ERROR-ALERT: RTMT Alert
Name:LowAvailableVirtualMemory Detail: Available virtual memory below 30 Percent. tomcat (975 MB) uses most of the memory.
The alert is generated on Thu Aug 05 18:11:31 EDT 2010 on node 172.29.0.180. Cluster ID: Node ID:CCM-PUB
Aaron Harrison Mon, 08/09/2010 - 00:41
  • Community Spotlight Award,
    Member's Choice, May 2015
Not sure of the specific bug, but I had one customer on 6.1(3) with very similar issues and upgraded them to 6.1(4) SU2 a few months back and all has been well for them since...
Aaron
claudiuprisecaru Sun, 10/17/2010 - 13:08
I have the same problem, a problem that appeared after the upgrade CUCM 7.1 to CUCM 8.0 (3). I attached the error that appears in RTM.
