Wireless AP 1252
pradip.saha
I have two lan segments.  I have few queries ragrading the wireless connectivity between these two lan segments.
1) Can I use AP 1252 as a bridge to connect both these lan segments ?
2) If yes, which radio will it use 802.11g/802.11n ( AP 1252 supports both g & n ) ?
3) If AP 1252 can be used to join both these lan segments via 802.11n, what mode do I need to configure it Autonomous/LWAPP ?
I need the answer asap. thanks in advance.
Leo Laohoo
What do you mean?  I understand that you have to LANs.  Can you clarify what you mean by "segments"?  Do you have, say, VLAN 4 and VLAn 9 and you want them to communicate with each other?
Or do you mean that you have two sites but with one VLAN and you want to link them together with a pair of 1250.  If this is the case, then  wireless point-to-point is the way to go.  I'd recommend you use Autonomous IOS to get this to work.
Wireless Bridges Point-to-Point Link Configuration Example
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008058f53e.shtml
