Intervlan routing on cisco asa 5510
Aug 9th, 2010
Hi All,
I doing a lab with a ASA 5510 with a 2590 switch and I would like see a simple code example doing intervaln routing cisco asa 5510.
Now in my lab isn´t not working. Do it have some secret ??
Antonio
Overall Rating: 3 (2 ratings)
Nagaraja Thanthry Mon, 08/09/2010 - 06:07
If you are trying inter-vlan routing, then make sure that both
sub-interfaces have a nameif and security level set to same value.
int eth 0/0.1
nameif inside1
security-level 100
exit
int eth 0/0.2
nameif inside2
security-level 100
exit
Then also make sure that NAT is turned off.
no nat-control
Finally, configure rule to allow communication between two interfaces with
same security level.
same-security-traffic permit inter-interface
Also, make sure that the hosts in different vlans have their respective
gateways set to firewalls respective sub-interface IP.
Hope this helps.
NT
Antonio Brandao Mon, 08/09/2010 - 09:09
Hi Nagaraja,
I did try it, but still not working, see below my actual conf.
One question, if disable my nat with no nat-control command, will I be able to do nat ?
fwljlpenglda1# sh run
: Saved
ASA Version 7.0(8)
hostname fwljlpenglda1
domain-name default.domain.invalid
enable password fcAtuJXQCdxxcGDJ encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
dns-guard
interface Ethernet0/0
no nameif
no security-level
no ip address
interface Ethernet0/0.501
description outside_internet
vlan 501
nameif outside_1
security-level 0
ip address 10.1.1.2 255.255.255.0
interface Ethernet0/0.502
description outside_dmz
vlan 502
nameif outside_2
security-level 0
ip address 10.1.2.2 255.255.255.0
interface Ethernet0/1
no nameif
no security-level
no ip address
interface Ethernet0/1.10
description users_lan
vlan 10
nameif inside_1
security-level 100
ip address 192.168.10.1 255.255.255.0
interface Ethernet0/1.20
description serv_farm
vlan 20
nameif inside_2
security-level 100
ip address 192.168.20.1 255.255.255.0
interface Ethernet0/1.40
description telephony
vlan 40
nameif inside_3
security-level 100
ip address 192.168.40.1 255.255.255.0
interface Ethernet0/1.50
description guest_lan
vlan 50
nameif inside_4
security-level 100
ip address 192.168.50.1 255.255.255.0
interface Ethernet0/2
description dmz
shutdown
nameif dmz
security-level 50
ip address 192.168.30.1 255.255.255.0
interface Management0/0
nameif management
security-level 100
management-only
ftp mode passive
access-list lan10 extended permit ip any any
access-list lan20 extended permit ip any any
pager lines 24
logging asdm informational
mtu outside_1 1500
mtu outside_2 1500
mtu inside_1 1500
mtu inside_2 1500
mtu inside_3 1500
mtu inside_4 1500
mtu dmz 1500
mtu management 1500
icmp permit any echo outside_1
icmp permit any echo-reply outside_1
icmp permit any echo inside_1
icmp permit any echo-reply inside_1
icmp permit any echo inside_2
icmp permit any echo-reply inside_2
asdm image disk0:/asdm-508.bin
no asdm history enable
arp timeout 14400
global (outside_1) 1 interface
nat (inside_1) 1 192.168.10.0 255.255.255.0
static (dmz,outside_2) 192.168.30.1 10.1.2.2 netmask 255.255.255.255
route outside_1 0.0.0.0 0.0.0.0 10.1.1.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
username root password hTcSpHuGLTErwasr encrypted privilege 15
http server enable
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd lease 3600
dhcpd ping_timeout 50
dhcpd enable management
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
  inspect dns maximum-length 512
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
service-policy global_policy global
Cryptochecksum:b0a4079e123e6b3eece868eee6659ff9
: end
Nagaraja Thanthry Mon, 08/09/2010 - 09:19
When you disable nat control, the firewall will not compel you to configure
NAT between every interface pair. However, if you did configure NAT, the
firewall will apply those rules and perform NAT as usual.
Hope this helps.
NT
Nay Myo Tun Wed, 11/17/2010 - 06:27
Hi NT ,
             Could you please help to advise? I have issue on my project . I have already setup the ASA 5510 and configured eth0 for outside ( security-level 0) , eth1 for DMZ (security-level 50 ) and eth3 for internal network ( security-level 100 ). I want to route / ftp to ping / ftp from each VLAN to another .
I have configured the necessary ACL to allow the traffic ( DMZ <=> Outside ) interfaces .
Using packet tracer from Outside to DMZ , the packet is allowed. But I can't ping / ftp from one interface to another . Pls. see the attached screen shot.
But according to your statement, "  If you are trying inter-vlan routing, then make sure that both sub-interfaces have a nameif and security level set to same value."
              Does it apply to DMZ , internal and external interfaces with diff security level ? Really appreciate your advise since I am now confused.
Antonio Brandao Wed, 11/17/2010 - 07:03
Hi Nay,
From where aren´t u able to ping who ? Only ping ? or U can´t reach the ftp server trought ftp services aswell ?
AB
underthesiege Mon, 08/09/2010 - 10:05
Try using "same-security-traffic permit intra-interface" command not "inter-interface" Cause you want to route between the networks which are
logically connected to your ethernet0/1 interface which is the same interface for all your networks. And also after using this command
don't forget to change your Internet and DMZ interfaces security level because of security reasons,
Hope this helps,
Antonio Brandao Wed, 08/11/2010 - 00:47
Hi NT,
Is not my idea turn off nat on firewall I will need in future to give these vlans access to internet trought outside_1 interface.
Thanks anyway by your help.
Underthesiege,
Did both commands and still not working, from firewall I can ping both lan, but from vlan10 I m not able to ping any host on vlan20
So still no working, follow my updated conf :
: Saved
ASA Version 7.0(8)
names
dns-guard
no nameif
no security-level
no ip address
vlan 501
nameif outside_1
security-level 0
vlan 502
nameif outside_2
security-level 0
no nameif
no security-level
no ip address
vlan 10
nameif inside_1
security-level 100
vlan 20
nameif inside_2
security-level 100
vlan 40
nameif inside_3
security-level 100
vlan 50
nameif inside_4
security-level 100
description dmz
shutdown
nameif dmz
security-level 50
nameif management
security-level 100
management-only
ftp mode passive
pager lines 24
mtu outside_1 1500
mtu outside_2 1500
mtu inside_1 1500
mtu inside_2 1500
mtu inside_3 1500
mtu inside_4 1500
mtu dmz 1500
mtu management 1500
arp timeout 14400
static (inside_1,inside_2) 192.168.20.0 192.168.10.0 netmask 255.255.255.0
static (inside_2,inside_1) 192.168.10.0 192.168.20.0 netmask 255.255.255.0
access-group lan10 in interface inside_1
access-group lan20 in interface inside_2
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd lease 3600
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
: end
Nagaraja Thanthry Wed, 08/11/2010 - 06:46
The static statements you have configured are incorrect. Please remove the
following lines:
no static (inside_1,inside_2) 192.168.20.0 192.168.10.0 netmask
255.255.255.0
no static (inside_2,inside_1) 192.168.10.0 192.168.20.0 netmask
255.255.255.0
Please configure the following lines:
static (inside_1,inside_2) 192.168.10.0 192.168.10.0 netmask 255.255.255.0
static (inside_2,inside_1) 192.168.20.0 192.168.20.0 netmask 255.255.255.0
Hope this helps.
NT
Antonio Brandao Wed, 08/11/2010 - 08:30
Hi NT,
Thanks it worked nicely. Is pinging now perfectly.
Great for that.
regards
Antonio
Hello Nagaraj,
I have same configuration and want to do communication between Two LAN SubInterface on ASA 5510 version 8.3.
I have tried to follow your given steps but no luck.
1) Same Security Level for Both VLAN Interface
2) Run command - same-security-traffic permit inter-interface.
Please guide what to do next. I am running latest verion of ASA 5510 version 8.3
ASA Configuration:
names
description ASA Outside segment
speed 100
duplex full
nameif outside
security-level 0
ip address 62.173.33.67 255.255.255.240
description VLAN AGGREGATION point
no nameif
no security-level
no ip address
vlan 2
nameif INSIDE
security-level 100
ip address 192.168.172.1 255.255.255.0
interface Ethernet0/1.3
description LAN Segment
vlan 3
nameif LAN
security-level 100
ip address 192.168.173.1 255.255.255.0
description VoIP network segment
vlan 4
nameif VOIP
security-level 90
ip address 192.168.174.1 255.255.255.0
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
nameif management
security-level 100
ip address 192.168.175.1 255.255.255.0
management-only
ftp mode passive
object network INSIDE
subnet 192.168.172.0 255.255.255.0
object network LAN
subnet 192.168.173.0 255.255.255.0
object network WEB_TEST
host 192.168.173.120
object network ISR
host 192.168.172.69
access-list outside-in extended permit tcp any object WEB_TEST eq www
access-list outside-in extended permit ip any object ISR
access-list vlan3-in extended permit tcp object WEB_TEST eq www any
access-list vlan2-in extended permit ip object ISR any
pager lines 24
mtu outside 1500
mtu INSIDE 1500
mtu LAN 1500
mtu VOIP 1500
mtu management 1500
icmp unreachable rate-limit 1 burst-size 1
arp timeout 14400
nat (INSIDE,outside) dynamic interface
object network LAN
nat (LAN,outside) dynamic interface
nat (LAN,outside) static 62.173.33.77
access-group outside-in in interface outside
access-group vlan3-in in interface LAN
route outside 0.0.0.0 0.0.0.0 62.173.33.65 1
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication enable console LOCAL
aaa authentication ssh console LOCAL
aaa authentication http console LOCAL
aaa authorization command LOCAL
aaa authorization exec LOCAL
http server enable
http 192.168.172.150 255.255.255.255 LAN
http 192.168.173.100 255.255.255.255 LAN
http 192.168.173.150 255.255.255.255 LAN
http 192.168.175.150 255.255.255.255 management
vpn-addr-assign local reuse-delay 5
telnet timeout 5
ssh 192.168.172.150 255.255.255.255 INSIDE
ssh 192.168.173.100 255.255.255.255 LAN
ssh 192.168.173.150 255.255.255.255 LAN
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
username Rakh password EV9pEo1UkhHJSbIW encrypted privilege 15
username Sigma password x0qPjGQ7LLxUxZ9k encrypted privilege 15
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
prompt hostname context
Cryptochecksum:77577f5b1d4d3927d0f656cf94dcd487
: end
Related Content
