Can I add FE to 2620 Router
Answered Question
Aug 9th, 2010
Is there a way to add a second 100 Mbps Fast Ethernet port to a Cisco 2620? All I am finding is 10Mb or non compatible.
Correct Answer by Reza Sharifi about 6 years 7 months ago
Hi Jack,
You can get 10/100 network module for it.
NM-1FE-TX is 10/100.
Here is the data sheet:
http://www.cisco.com/warp/public/cc/pd/rt/3600/prodlit/3600m_ds.pdf
Reza
Overall Rating: 5 (1 ratings)
relsethagen Mon, 08/09/2010 - 20:07
I'm pretty sure, and the link suggested confirms that the network modules for fast Ethernet are not supported on the 2600 platform only on 3600 platform.
Jack Pegnam Tue, 08/17/2010 - 03:22
I had already ordered the NM-1FE-TX  before I saw the comments saying it would not work. I have it installed and all looks good.
They were not alone. There were many other sites saying it would not work either, but it is woking for me.
Thanks for your help.
relsethagen Mon, 08/09/2010 - 21:00
I've looked for a FE interface for the 2620 before, and I'm pretty sure it is a brick wall
Table 3. Maximum Number of Network Modules that Are Supported in the 2600, 2691, 3600, 3700 and 3800 Families
2600
2691
2800
3640
3660
3725/3825
3745/3845
NM-1FE2 and NM-1FE2W-V2
N/A
N/A
NM-2FE2W and NM-2FE2W-V2
N/A
N/A
NM-1FE1R2W
N/A
N/A
NM-2W
N/A
NM-1FE-FX-V2
N/A
N/A
pgmrdude1 Sun, 04/17/2011 - 17:42
How in the world can it work for some people with a 2620 (not xm) but NOT for others?? I also don't understand why, if the built-in card is FE, why would the additional FE (NM-1FE-TX) NOT work?? For those of you who got it to work - do you have the XM models or the 2RU? Is there a partocular IOS that will allow the 1FEs to work with a 2620? Perhaps that is the difference. I have just the plain-jane 1RU 2620 with one FE port, one console, one aux and 2 WAN slots. I don't want to waste my money and end up with an expensive paperweight, and I don't want to settle for standard Eth if I can have FE.
Thanks all!! Can we just ask Cisco???
