chrhiggi Mon, 08/09/2010 - 15:52
Hello Jaime-
The GSS has a "shutdown" command at the enable prompt.
For the ACE 4710 - you can hold down the power button on the front, there is no cli command.
For the ACE10-mod-k9 and ACE20-mod-k9, you can issue "no power enable module X"
On a side note, there is a "shutdown" button on the front of the ACE modules that you can use a paperclip to access. However, functionality of this button is actually to reset the module, not power it off.
cat-1#sh module
Mod Ports Card Type                              Model              Serial No.
  1    6  Firewall Module                        WS-SVC-FWM-1       SAD084305R8
  2    1  Application Control Engine Module      ACE10-6500-K9      SAD094701MY
  3    1  Application Control Engine Module      ACE20-MOD-K9       SAD1141053B
  5    2  Supervisor Engine 720 (Active)         WS-SUP720-3BXL     SAD081200ES
  6   48  48-port 10/100 mb RJ45                 WS-X6148-RJ45V     SAL0651ADR6
  9    3  AON Module                             WS-SVC-AON-1-K9    SAD08320722
cat-1(config)#no power enable module ?
  <1-9>  module slot number
cat-1(config)#no power enable module 3
%Power admin state updated
Chris Higgins
