ASA 5505 to 5510 established but no traffic
Aug 9th, 2010
I've established a site-to-site connection between the devices, but cannot get any traffic.  Both ends can still reach Internet, but cannot ping any addresses either way, nor browse or other traffic.  I have no idea how to debug, can post anything for help.
Under monitoring, it shows the connection is established.
Thanks in advance
Nagaraja Thanthry Mon, 08/09/2010 - 08:24
  • Cisco Employee,
Do you have appropriate nat-0 rules for the traffic to go over the tunnel?
access-list nonat permit ip
nat (inside) 0 access-list nonat
If it is not there, please configure these and try again.
Hope this helps.
NT
manish arora Mon, 08/09/2010 - 08:26
  • Silver, 250 points or more
Can you post the configurations please ? also require sh crypto iskamp sa , sh crypto ipsec sa.  also issue command sysopt connection permit-vpn.
Manish
gene.mccullough Mon, 08/09/2010 - 08:46
ASA Version 8.3(1)
hostname ciscoasa
domain-name center.com
enable password JcssSZFNC1Tuf.uj encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address 192.168.1.99 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 67.XXXX 255.255.255.128
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
boot system disk0:/asa831-k8.bin
ftp mode passive
dns domain-lookup outside
dns server-group DefaultDNS
name-server 24.116.2.50
name-server 24.116.2.34
domain-name frisco-center.com
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network CityHall
subnet 172.16.100.0 255.255.252.0
description City Hall Network
object network NETWORK_OBJ_192.168.1.0_24
subnet 192.168.1.0 255.255.255.0
object-group network obj_any
access-list outside_1_cryptomap extended permit ip 192.168.1.0 255.255.255.0 object CityHall
access-list outside_1_cryptomap_1 extended permit ip 192.168.1.0 255.255.255.0 object CityHall
access-list nonat extended permit ip any any
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-631.bin
no asdm history enable
arp timeout 14400
nat (inside,outside) source dynamic any interface
nat (inside,outside) source static NETWORK_OBJ_192.168.1.0_24 NETWORK_OBJ_192.168.1.0_24 destination static CityHall CityHall
route outside 0.0.0.0 0.0.0.0 67.60.168.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map outside_map 1 match address outside_1_cryptomap_1
crypto map outside_map 1 set pfs group1
crypto map outside_map 1 set peer 24.116.132.42
crypto map outside_map 1 set transform-set ESP-3DES-MD5
crypto map outside_map interface outside
crypto isakmp identity address
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash md5
group 2
lifetime 86400
no crypto isakmp nat-traversal
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.1.103-192.168.1.134 inside
dhcpd auto_config outside interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy DfltGrpPolicy attributes
vpn-tunnel-protocol IPSec l2tp-ipsec
group-policy CityHallGroupPolicy internal
group-policy CityHallGroupPolicy attributes
tunnel-group 24.116.132.42 type ipsec-l2l
tunnel-group 24.116.132.42 general-attributes
default-group-policy CityHallGroupPolicy
tunnel-group 24.116.132.42 ipsec-attributes
pre-shared-key *****
tunnel-group CityHallTunnelGroup type ipsec-l2l
tunnel-group CityHallTunnelGroup general-attributes
tunnel-group CityHallTunnelGroup ipsec-attributes
peer-id-validate nocheck
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email [email protected]
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:f06c269985c47fead6b865d58f60f35d
: end
gene.mccullough Mon, 08/09/2010 - 08:53
Result of the command: "sh crypto isakmp sa"
   Active SA: 1
    Rekey SA: 0 (A tunnel will report 1 Active and 1 Rekey SA during rekey)
Total IKE SA: 1
1   IKE Peer: 24.116.132.42
    Type    : L2L             Role    : responder
    Rekey   : no              State   : MM_ACTIVE
Result of the command: "sh crypto ipsec sa"
interface: outside
    Crypto map tag: outside_map, seq num: 1, local addr: 67.60.168.34
      access-list outside_1_cryptomap_1 extended permit ip 192.168.1.0 255.255.255.0 172.16.100.0 255.255.252.0
      local ident (addr/mask/prot/port): (192.168.1.0/255.255.255.0/0/0)
      remote ident (addr/mask/prot/port): (172.16.100.0/255.255.252.0/0/0)
      current_peer: 24.116.132.42
      #pkts encaps: 9, #pkts encrypt: 9, #pkts digest: 9
      #pkts decaps: 3447, #pkts decrypt: 3447, #pkts verify: 3447
      #pkts compressed: 0, #pkts decompressed: 0
      #pkts not compressed: 9, #pkts comp failed: 0, #pkts decomp failed: 0
      #pre-frag successes: 0, #pre-frag failures: 0, #fragments created: 0
      #PMTUs sent: 0, #PMTUs rcvd: 0, #decapsulated frgs needing reassembly: 0
      #send errors: 0, #recv errors: 0
      local crypto endpt.: 67.60.168.34/0, remote crypto endpt.: 24.116.132.42/0
      path mtu 1500, ipsec overhead 58, media mtu 1500
      current outbound spi: 7B8155A0
      current inbound spi : 77675A2C
    inbound esp sas:
      spi: 0x77675A2C (2003261996)
         transform: esp-3des esp-md5-hmac no compression
         in use settings ={L2L, Tunnel, PFS Group 1, }
         slot: 0, conn_id: 24576, crypto-map: outside_map
         sa timing: remaining key lifetime (kB/sec): (4373776/26514)
         IV size: 8 bytes
         replay detection support: Y
         Anti replay bitmap:
          0xFFFFFFFF 0xFFFFFFFF
    outbound esp sas:
      spi: 0x7B8155A0 (2072073632)
         sa timing: remaining key lifetime (kB/sec): (4373999/26514)
         IV size: 8 bytes
         Anti replay bitmap:
          0x00000000 0x00000001
manish arora Mon, 08/09/2010 - 09:34
Umm.. you are using  8.3 version which comes with a new nat commands and i believe you are missing nat exempt for tunnel traffic , please try this :-
object network obj-192.168.x.x
  subnet 192.168.x.x
object network  obj-172.16.x.x
  subnet 172.16.x.x
nat (inside,any) source static obj-192.168.x.x obj-192.168.x.x destination static obj-172.16.x.x obj-172.16.x.x
any experts of 8.3 should comment on this if i am wrong.
thanks
Manish
gene.mccullough Mon, 08/09/2010 - 09:28
ASA Version 8.3(1)
hostname ciscoasa
domain-name clintonokla.org
names
name 192.168.1.0 FriscoCenter
dns-guard
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
description First floor of city hall
nameif FirstFloor
security-level 100
ip address 172.16.100.1 255.255.252.0
description CableOne ISP connection
nameif CableOne
security-level 0
ip address 24.116.132.42 255.255.255.248
interface Management0/0
description Used for management of device
nameif management
security-level 100
ip address 10.0.0.1 255.255.0.0
management-only
ftp mode passive
clock timezone CST -6
clock summer-time CDT recurring
object network obj-172.16.100.0
object network FriscoCenter
object network obj-172.16.101.89
host 172.16.101.89
object network obj-172.16.101.89-01
host 172.16.101.89
object network obj-172.16.102.50
host 172.16.102.50
object network obj-172.16.102.50-01
host 172.16.102.50
object network obj-172.16.102.50-02
host 172.16.102.50
object network obj-172.16.101.89-02
host 172.16.101.89
object network obj-172.16.101.89-03
host 172.16.101.89
object network obj-172.16.101.89-04
host 172.16.101.89
object network obj-172.16.101.89-05
host 172.16.101.89
object network obj-172.16.101.80
host 172.16.101.80
object network obj-172.16.101.25
host 172.16.101.25
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network obj-0.0.0.0
host 0.0.0.0
object network obj_any-01
object network AcmeBrick-network
subnet 192.168.10.0 255.255.255.0
description Acme Brick Park Network connected to CableOne
object network NETWORK_OBJ_172.16.100.0_22
object network NETWORK_OBJ_192.168.10.0_24
object-group network DM_INLINE_NETWORK_2
network-object host 24.116.132.43
network-object host 24.116.132.44
object-group service DM_INLINE_TCP_2 tcp
port-object eq 10000
port-object eq 8080
port-object eq www
port-object eq https
port-object eq ssh
object-group service DM_INLINE_TCP_1 tcp
port-object eq imap4
port-object eq pop3
port-object eq 465
port-object eq 993
port-object eq 995
object-group service DM_INLINE_TCP_3 tcp
port-object eq 5500
port-object eq 5900
object-group network DM_INLINE_NETWORK_1
network-object host 172.16.101.25
network-object host 172.16.101.89
access-list FirstFloor_nat0_outbound extended permit ip 172.16.100.0 255.255.252.0 object FriscoCenter
access-list ClintonWAN_splitTunnelAcl standard permit any
access-list 110 extended permit tcp host 192.168.1.44 any eq www inactive
access-list CableOne_1_cryptomap extended permit ip 172.16.100.0 255.255.252.0 object FriscoCenter
access-list CableOne_access_in extended permit tcp any any eq 3389
access-list CableOne_access_in remark Migration, ACE (line 2) expanded: permit tcp any object-group DM_INLINE_NETWORK_2 eq smtp
access-list CableOne_access_in extended permit tcp any host 172.16.101.25 eq smtp
access-list CableOne_access_in extended permit tcp any host 172.16.101.89 eq smtp
access-list CableOne_access_in remark Migration: End of expansion
access-list CableOne_access_in extended permit tcp any host 172.16.101.80 object-group DM_INLINE_TCP_2
access-list CableOne_access_in remark Migration, ACE (line 4) expanded: permit tcp any host 24.116.132.44 object-group DM_INLINE_TCP_1
access-list CableOne_access_in extended permit tcp any host 172.16.101.89 eq imap4
access-list CableOne_access_in extended permit tcp any host 172.16.101.89 eq pop3
access-list CableOne_access_in extended permit tcp any host 172.16.101.89 eq 465
access-list CableOne_access_in extended permit tcp any host 172.16.101.89 eq 993
access-list CableOne_access_in extended permit tcp any host 172.16.101.89 eq 995
access-list CableOne_access_in extended permit tcp any any object-group DM_INLINE_TCP_3
access-list CableOne_access_in extended permit tcp object-group DM_INLINE_NETWORK_1 any eq smtp
access-list CableOne_access_in extended deny tcp any any eq smtp
access-list CableOne_access_in remark Attempting to hack web server
access-list CableOne_access_in extended deny ip host 117.41.229.178 any
pager lines 24
logging enable
logging timestamp
logging list IP_Notification level notifications class ip
logging list VPN_DEBUG level debugging class vpdn
logging list VPN_DEBUG level debugging class vpn
logging list VPN_DEBUG level debugging class vpnc
logging list VPN_DEBUG level debugging class vpnfo
logging asdm-buffer-size 512
logging console debugging
logging monitor warnings
logging buffered errors
logging trap errors
logging asdm IP_Notification
logging mail VPN_DEBUG
logging from-address [email protected]
logging recipient-address
[email protected] level emergencies
logging host FirstFloor 172.16.101.80
logging debug-trace
logging permit-hostdown
mtu FirstFloor 1500
mtu CableOne 1500
mtu management 1500
icmp permit FriscoCenter 255.255.255.0 FirstFloor
icmp permit FriscoCenter 255.255.255.0 CableOne
arp timeout 14400
nat (FirstFloor,any) source static obj-172.16.100.0 obj-172.16.100.0 destination static FriscoCenter FriscoCenter
nat (FirstFloor,CableOne) source static NETWORK_OBJ_172.16.100.0_22 NETWORK_OBJ_172.16.100.0_22 destination static NETWORK_OBJ_192.168.10.0_24 NETWORK_OBJ_192.168.10.0_24
nat (FirstFloor,CableOne) dynamic interface
nat (FirstFloor,CableOne) static 24.116.132.44 service tcp pop3 pop3
nat (FirstFloor,CableOne) static 24.116.132.44 service tcp imap4 imap4
nat (FirstFloor,CableOne) static 24.116.132.46 service tcp 5500 5500
nat (FirstFloor,CableOne) static 24.116.132.46 service tcp 3389 3389
nat (FirstFloor,CableOne) static 24.116.132.46 service tcp 5900 5900
nat (FirstFloor,CableOne) static 24.116.132.44 service tcp smtp smtp
nat (FirstFloor,CableOne) static 24.116.132.44 service tcp 993 993
nat (FirstFloor,CableOne) static 24.116.132.44 service tcp 995 995
nat (FirstFloor,CableOne) static 24.116.132.44 service tcp 465 465
nat (FirstFloor,CableOne) static 24.116.132.45
nat (FirstFloor,CableOne) static 24.116.132.43
nat (FirstFloor,CableOne) dynamic obj-0.0.0.0
nat (management,CableOne) dynamic obj-0.0.0.0
access-group CableOne_access_in in interface CableOne
route-map proxy-redirect permit 10
match ip address 110
set metric 1
route CableOne 0.0.0.0 0.0.0.0 24.116.132.41 10
aaa authentication ssh console LOCAL
aaa authorization command LOCAL
http server enable 543
http 10.0.0.52 255.255.255.255 management
http 10.0.0.0 255.255.0.0 management
http 10.0.0.44 255.255.255.255 management
http 192.168.1.44 255.255.255.255 management
http FriscoCenter 255.255.255.0 management
http 192.168.1.184 255.255.255.255 management
http 172.16.102.50 255.255.255.255 management
http 67.61.228.229 255.255.255.255 CableOne
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-SHA
crypto dynamic-map outside_dyn_map 40 set transform-set ESP-3DES-SHA
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map CableOne_map 1 match address CableOne_1_cryptomap
crypto map CableOne_map 1 set pfs group1
crypto map CableOne_map 1 set peer 67.60.168.34
crypto map CableOne_map 1 set transform-set ESP-3DES-MD5
crypto map CableOne_map 1 set nat-t-disable
crypto map CableOne_map 1 set reverse-route
crypto map CableOne_map interface CableOne
crypto ca trustpoint ASDM_TrustPoint0
enrollment self
email
[email protected]
subject-name CN=ciscoasa
serial-number
ip-address 24.116.132.42
proxy-ldc-issuer
crl configure
crypto ca certificate chain ASDM_TrustPoint0
certificate cbb0284c
    308202b4 3082021d a0030201 020204cb b0284c30 0d06092a 864886f7 0d010105
    0500306c 3111300f 06035504 03130863 6973636f 61736131 57301206 03550405
    130b4a4d 58313233 354c3139 33301a06 092a8648 86f70d01 0908130d 32342e31
    31362e31 33322e34 32302506 092a8648 86f70d01 09021618 63697363 6f617361
    2e636c69 6e746f6e 6f6b6c61 2e6f7267 301e170d 31303037 32323139 34353031
    5a170d32 30303731 39313934 3530315a 306c3111 300f0603 55040313 08636973
    636f6173 61315730 12060355 0405130b 4a4d5831 3233354c 31393330 1a06092a
    864886f7 0d010908 130d3234 2e313136 2e313332 2e343230 2506092a 864886f7
    0d010902 16186369 73636f61 73612e63 6c696e74 6f6e6f6b 6c612e6f 72673081
    9f300d06 092a8648 86f70d01 01010500 03818d00 30818902 818100b7 8171a7d6
    86ee32f8 4bc68b40 5b8143ab ad430393 a30ca76d c47b8fb9 2b9f42aa c0941620
    4b1b8341 c9275fbe 9024f62a 1d2d663b 279fc9a3 b04bdc0d ca431089 2797ebcd
    21517879 926046fd 455fdb7f fb6c97ad d0c0f9d4 69aad3ce 8b5c6068 bfd182d2
    6edbfe92 684023e6 768abce4 ed9d75db 95aeee65 08722885 b3cb9d02 03010001
    a3633061 300f0603 551d1301 01ff0405 30030101 ff300e06 03551d0f 0101ff04
    04030201 86301f06 03551d23 04183016 80141127 b47e3e38 5f942500 7827acb4
    a82e6202 b754301d 0603551d 0e041604 141127b4 7e3e385f 94250078 27acb4a8
    2e6202b7 54300d06 092a8648 86f70d01 01050500 03818100 b34e1d2c 16b52f27
    85ea015f 359d383f aa71d264 878f3cef 457f1265 1e845c94 f82d602a 63de9b45
    adff8d47 58ee5fbf 409a5aea 4ebfc7b6 72182b01 678917a1 ffe6e3d7 ef469127
    81cf495a 9bece16b 5b4e2920 84e38afa 93518651 45d170fc 924f9dff a45595cf
    7faae1c2 62fdb73a e86f443a ba638eb8 2438cff3 b7faf1cb
  quit
crypto isakmp enable CableOne
crypto isakmp policy 5
encryption 3des
hash md5
group 2
lifetime 86400
client-update enable
telnet timeout 5
ssh 192.168.1.91 255.255.255.255 management
ssh 10.0.0.0 255.255.0.0 management
ssh timeout 15
console timeout 0
management-access management
threat-detection statistics port
threat-detection statistics protocol
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
webvpn
svc image disk0:/sslclient-win-1.1.0.154.pkg 1
svc enable
group-policy AcmeGroupPolicy internal
group-policy AcmeGroupPolicy attributes
group-policy CityGroupPolicy internal
group-policy CityGroupPolicy attributes
vpn-filter none
username gene password TN3sFvBSa44uSGUN encrypted privilege 15
username gene attributes
vpn-group-policy DfltGrpPolicy
tunnel-group 67.60.168.34 type ipsec-l2l
tunnel-group 67.60.168.34 general-attributes
default-group-policy CityGroupPolicy
tunnel-group 67.60.168.34 ipsec-attributes
policy-map type inspect dns migrated_dns_map_1
parameters
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ftp
  inspect icmp
  inspect ip-options
class class-default
  csc fail-open
  inspect pptp
policy-map type inspect ftp Clinton
parameters
  mask-syst-reply
policy-map type inspect http CLINTON
parameters
  protocol-violation action log
match request header content-type violation
  log
match response header content-type violation
  log
smtp-server 172.16.101.25 172.16.101.89
privilege cmd level 3 mode exec command perfmon
privilege cmd level 3 mode exec command ping
privilege cmd level 3 mode exec command who
privilege cmd level 3 mode exec command logging
privilege cmd level 3 mode exec command failover
privilege cmd level 3 mode exec command vpn-sessiondb
privilege show level 5 mode exec command running-config
privilege show level 3 mode exec command reload
privilege show level 3 mode exec command mode
privilege show level 3 mode exec command firewall
privilege show level 3 mode exec command interface
privilege show level 3 mode exec command clock
privilege show level 3 mode exec command dns-hosts
privilege show level 3 mode exec command access-list
privilege show level 3 mode exec command logging
privilege show level 3 mode exec command ip
privilege show level 3 mode exec command failover
privilege show level 3 mode exec command asdm
privilege show level 3 mode exec command arp
privilege show level 3 mode exec command route
privilege show level 3 mode exec command ospf
privilege show level 3 mode exec command aaa-server
privilege show level 3 mode exec command crypto
privilege show level 3 mode exec command vpn-sessiondb
privilege show level 3 mode exec command ssh
privilege show level 3 mode exec command dhcpd
privilege show level 3 mode exec command blocks
privilege show level 3 mode exec command uauth
privilege show level 3 mode configure command interface
privilege show level 3 mode configure command clock
privilege show level 3 mode configure command access-list
privilege show level 3 mode configure command logging
privilege show level 3 mode configure command ip
privilege show level 3 mode configure command failover
privilege show level 5 mode configure command asdm
privilege show level 3 mode configure command arp
privilege show level 3 mode configure command route
privilege show level 3 mode configure command aaa-server
privilege show level 3 mode configure command crypto
privilege show level 3 mode configure command vpn-sessiondb
privilege show level 3 mode configure command ssh
privilege show level 3 mode configure command dhcpd
privilege show level 5 mode configure command privilege
privilege clear level 3 mode exec command dns-hosts
privilege clear level 3 mode exec command logging
privilege clear level 3 mode exec command arp
privilege clear level 3 mode exec command aaa-server
privilege clear level 3 mode exec command crypto
privilege cmd level 3 mode configure command failover
privilege clear level 3 mode configure command logging
privilege clear level 3 mode configure command arp
privilege clear level 3 mode configure command crypto
privilege clear level 3 mode configure command aaa-server
call-home
profile CiscoTAC-1
  no active
[email protected]
Cryptochecksum:5e7fbe56f0b17cc8a50efe9dbde1093f
: end
gene.mccullough Mon, 08/09/2010 - 09:30
   Active SA: 1
Total IKE SA: 1
1   IKE Peer: 67.60.168.34
    Type    : L2L             Role    : initiator
interface: CableOne
    Crypto map tag: CableOne_map, seq num: 1, local addr: 24.116.132.42
      access-list CableOne_1_cryptomap extended permit ip 172.16.100.0 255.255.252.0 192.168.1.0 255.255.255.0
      local ident (addr/mask/prot/port): (172.16.100.0/255.255.252.0/0/0)
      remote ident (addr/mask/prot/port): (192.168.1.0/255.255.255.0/0/0)
      current_peer: 67.60.168.34
      #pkts encaps: 6752, #pkts encrypt: 6752, #pkts digest: 6752
      #pkts decaps: 18, #pkts decrypt: 18, #pkts verify: 18
      #pkts not compressed: 6752, #pkts comp failed: 0, #pkts decomp failed: 0
      local crypto endpt.: 24.116.132.42/0, remote crypto endpt.: 67.60.168.34/0
      current outbound spi: 77675A2C
      current inbound spi : 7B8155A0
    inbound esp sas:
         slot: 0, conn_id: 3596288, crypto-map: CableOne_map
         sa timing: remaining key lifetime (kB/sec): (3914999/24255)
         IV size: 8 bytes
         Anti replay bitmap:
          0x00000000 0x0007FFFF
    outbound esp sas:
         sa timing: remaining key lifetime (kB/sec): (3914560/24255)
         IV size: 8 bytes
         Anti replay bitmap:
manish arora Mon, 08/09/2010 - 09:37
Yeah , looking at the other end configuration , you are missing the nat exempt commands , check my previous reply and update that on your asa. you can see the nat exempt on your last asa config upload.
hope it helps
manish
gene.mccullough Mon, 08/09/2010 - 10:01
Thank you for looking, I've applied those commands successfully, but I still can't ping across, either direction.
I had this working with a cisco RVS4000 before replacing with the 5505
manish arora Mon, 08/09/2010 - 10:08
Can you recheck the crypto ipsec sa and see if the 5505 asa has now started to encrypt packets when you send traffic from 192.168.x.x to 172.16.x.x site ?
gene.mccullough Mon, 08/09/2010 - 11:49
To me, the untrained eye, they look the same as previous post.   Thanks, gene
Result of the command: "sho crypto ipsec sa"
interface: outside
      #pkts encaps: 51, #pkts encrypt: 51, #pkts digest: 51
      #pkts decaps: 18722, #pkts decrypt: 18722, #pkts verify: 18722
      #pkts not compressed: 51, #pkts comp failed: 0, #pkts decomp failed: 0
    inbound esp sas:
         sa timing: remaining key lifetime (kB/sec): (4372782/16095)
         IV size: 8 bytes
         Anti replay bitmap:
    outbound esp sas:
         sa timing: remaining key lifetime (kB/sec): (4373998/16095)
         IV size: 8 bytes
         Anti replay bitmap:
gene.mccullough Mon, 08/09/2010 - 12:06
I see this in the log from 5505, trying to ping from the 5510 side.  Looks like it is getting into
the 5505, but not back out.
3Aug 09 201011:54:09305006172.16.102.50regular translation creation failed for icmp src inside:192.168.1.70 dst outside:172.16.102.50 (type 0, code 0)
6Aug 09 201011:54:09302020172.16.102.501192.168.1.700Built inbound ICMP connection for faddr 172.16.102.50/1 gaddr 192.168.1.70/0 laddr 192.168.1.70/0
manish arora Mon, 08/09/2010 - 12:16
On the 5510 asa, can you remove  the following :-
then remove the crypto map from both asa's outside and then reapply them
thanks
Manish
gene.mccullough Mon, 08/09/2010 - 13:08
I am able now to rdp into a machine behind th 5505, but still no ping ability.  Thanks for all of your help!
gene
manish arora Mon, 08/09/2010 - 13:18
Not able to ping but you can rdp means that the device is running some kind of firewall on it or anti virus with firewall capability.
thanks
Manish
gene.mccullough Mon, 08/09/2010 - 14:30
Unfortunately, can't ping anything, either direction.  Cannot browse windows shares, or ping, but can rdp to machines that are enabled.  Any thoughts?
Thanks again, gene
manish arora Mon, 08/09/2010 - 14:43
Issue command  sysopt connection permit-vpn  on both the firewalls. Try windows share using ip address also you might have to reduce the TCP MSS on the windows fileshare to accomodate the ipsec encapsulation on the ip packet. also, check again for any local server or machine firewall is truned off and inside access list on firewall are set on permit any any.
thanks
Manish
