08-09-2010 08:31 AM - edited 03-06-2019 12:23 PM
Can someone point me in the direction of the commands or the documentation that i would use to upgrade the IOS on a 3750-E
that i have through TFTP.
Solved! Go to Solution.
08-09-2010 08:55 AM
Please follow the following link:
You can go to Feature navigator and compare IOS version which would suit your needs:
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
podhillo
08-09-2010 08:55 AM
podhillo
08-09-2010 09:27 AM
Would you happen to know just the basic commands for upgrading a switch or router through TFTP
08-09-2010 11:23 AM
Depends on whether you want to copy the whole tar directory or just the .bin file but the link provided by Podhillo has all the instructions in there, step by step.
Is there something else you need clarifying ?
Jon
08-09-2010 11:25 AM
No that was it, i will just read the document
