greenturtlesteak Mon, 08/09/2010 - 09:06
  • Bronze, 100 points or more
If you are running the latest version of CUE you can schedule recurring backups to an FTP server. However, this functionality does not exist for the CME side of things. You'll need backup your IOS config whenever changes are made.
If you are complying to the CCA OOB config guidlines then you can use CCA to do a full backup of all system content, but I'm pretty sure this can not be on a recurring schedule.
Cole
pro4ianyc Mon, 08/09/2010 - 09:11
I see the option from the GUI as you mentioned.
Is having a backup from CUE gui and the latest running config enough to restore the system to a new hardware incase of hardware failure?
or do you recommend CCA backup over this method?
Is there a guide here on how to properly backup the system and restore in case of disaster?  Thanks for your response.
greenturtlesteak Mon, 08/09/2010 - 09:15
Having a CUE backup of at least the configuration and data as well as the IOS config will be enough to restore the entire system. CCA backup should be good enough as well. You can never have too many backups.
Also, make sure the hardware is the same as you could run into some problems restoring to different hardware, particularly with CUE.
pro4ianyc Mon, 08/09/2010 - 10:06
I agree.  I think hardware and also the software version should be important.  Thanks for the info.
Related Content
