Transparente bridging with pppoe
Aug 9th, 2010
Hi people
I wonder what device should I buy to do pppoe dialing with TB in a fiber link so that i can use the public IP in the firewall that was behind. This diagram
isp ---> device dialing pppoe ( no adsl ) ---> firewall ----> lan
i want to use the fixed public ip  in the firewall not in the pppoe client device.
I can do this? is it possible? which would be the model of device?
regards
marcos
paolo bevilacqua Mon, 08/09/2010 - 14:07
  • Hall of Fame,
    Founding Member
Use whatever device from ISP and terminate PPPoE on firewall.
ciscomiloja Mon, 08/09/2010 - 14:31
I can not, that's the problem, if I put the firewall in the cluster, which is what I need to do, I can not dial pppoe, so I need another device ( the firewall is a fortigate )
paolo bevilacqua Mon, 08/09/2010 - 15:45
  • Hall of Fame,
    Founding Member
If your FW cannot do PPPoE, get a better FW.
You can bridge PPPoE no problem, but if your FW is unable to terminate it, then it is not useful.
Related Content
