Nexus 7010
Aug 9th, 2010
Does anyone know if the nexus 7k copper blade ports is the spanning-tree portfast is enable by default. And if there is a server on one port can you manually turn it on not sure if to set it for edge or normal port type.
Overall Rating: 5 (1 ratings)
dirao Wed, 08/11/2010 - 14:35
  • Cisco Employee,
Portfast is not enabled by default on any of the modules, as the default spanning tree port type is normal, i.e the port transitions through the regular spanning tree states.
You could configure the port connecting to the server with 'spanning-tree port type edge' to enable portfast on it.
Here are some reference docs on this.
http://www.cisco.com/en/US/docs/solutions/Enterprise/Data_Center/nx_7000_dc.html#wp873712
http://www.cisco.com/en/US/docs/switches/datacenter/sw/4_2/nx-os/layer2/configuration/guide/Cisco_Nexus_7000_Series_NX-OS_Layer_2_Switching_Configuration_Guide_Release_4.2_chapter8.html#con_1285186
Hope this helps.
Divya
darren.g Sun, 09/19/2010 - 20:46
  • Silver, 250 points or more
The "defaults" for a lot of things on a N7K are configurable. Well, they are in NXOS V5, which I am running.
If you enter the following command
nexus(config)# spanning-tree port type edge default
Then the answer to your question is yes. But this will change EVERY port, regardless of how it is configured, so unless your Nexus is a greenfield setup, I wouldn't recommend it.
You can manually change any port type to edge (spanning-tree portfast) either one by one, or in a range, for example
nexus(config)# interface ethernet 1/1 - 48
nexus(config-if-range)# spanning-tree port type edge
nexus(config-if-range)# end
will set ports Ethernet 1/1 through 1/48 in portfast mode (note that the space between the 1 and the 48 when specifying a range is obligatory). Of course, you can do one port at a time simply by specifying it as ethernet 1/5, for example.
Cheers.
Trending Topics: Other DC Subjects
