VSS
Answered Question
Aug 9th, 2010
what is the most recent update about the VSS with two in-chassi supervisors on each 6509E?.
Is VSS with 2xsup´s in-chassi supported today?.
Thanks.
Correct Answer by Reza Sharifi about 6 years 7 months ago
The most recent update when using SXI4 or SXI4a is support of multiple Sups per chassis.
You do want to use SXI4a, because there ware some MPLS components missing in SXI4.
Reza
Overall Rating: 5 (1 ratings)
Correct Answer
Reza Sharifi Mon, 08/09/2010 - 12:42
  • Cisco Designated VIP,
    2017 LAN
Reza
