david.macias Mon, 08/09/2010 - 16:21
  • Blue, 1500 points or more
Did you try increasing the number of channels in the media group?
david
c.carrion Mon, 08/09/2010 - 17:31
Hi. David Macias.
Did you mean a media resource group in the cisco callmanager ?
Additionally,I am using Cisco Contact Center Express  7.0(1)SR05_Build504   This contact Center is integrated with CUCM 7.1.3.30000-1.
As soon as I restart the server (IPCC), the problem is resolved and it looks like nothing is wrong
why did it failed ,Any idea?
Thanks for your help.
c.carrion Mon, 08/09/2010 - 21:29
Hi.
Attach additional information:
13842750: Aug 07 07:08:45.717 COT %MIVR-EXECUTOR_MGR-7-THREAD_ALLOCATED:Thread allocated: Facility=MIVR,Sub-Facility=SS_TEL,Executor id=TPG_EXE,Thread=MIVR_SS_TEL_TPG_EXE-45-12982,Thread priority=5,Original Thread=ExecutorManagerImpl.pool-3274
13842751: Aug 07 07:08:45.717 COT %MIVR-SS_TEL-7-UNK:RP[num=3010], conn=[3010:P_HELPDESK:1/(P1-jtapi_user_2) GCID=(3,5174)->INVALID]->DISCONNECTED, event=CallCtlConnDisconnectedEv, cause=Other: 17[17], meta=META_CALL_ENDING[132]
13842752: Aug 07 07:08:45.717 COT %MIVR-CHANNEL_MGR-7-UNK:GroupStubImpl::findAndLockIdleChannel() - inside method-GroupStub[channelClass=com.cisco.crs.jtapi.JTAPICallControlChannel,type=Cisco CTI Port,id=11,name=11,state=PARTIAL_SERVICE,channel=5]
13842753: Aug 07 07:08:45.717 COT %MIVR-CHANNEL_MGR-7-UNK:ChStubImpl:getChannelLock() -id=6 trying to get channel lock ...
13842754: Aug 07 07:08:45.717 COT %MIVR-CHANNEL_MGR-7-UNK:ChStubImpl:getChannelLock() - Could not get channel lock-ChannelStub[channelClass=com.cisco.call.CallControlChannel,type=Cisco CTI Port,id=6,state=IN_USE,pendingState=null,groupId=11,locked=false]
13842755: Aug 07 07:08:45.717 COT %MIVR-CHANNEL_MGR-7-UNK:ChStubImpl:getChannelLock() -id=7 trying to get channel lock ...
13842756: Aug 07 07:08:45.717 COT %MIVR-CHANNEL_MGR-7-UNK:ChStubImpl:getChannelLock() - Could not get channel lock-ChannelStub[channelClass=com.cisco.call.CallControlChannel,type=Cisco CTI Port,id=7,state=OUT_OF_SERVICE,pendingState=null,groupId=11,locked=false]
13842757: Aug 07 07:08:45.717 COT %MIVR-CHANNEL_MGR-7-UNK:ChStubImpl:getChannelLock() -id=3 trying to get channel lock ...
13842758: Aug 07 07:08:45.717 COT %MIVR-CHANNEL_MGR-7-UNK:ChStubImpl:getChannelLock() - Could not get channel lock-ChannelStub[channelClass=com.cisco.call.CallControlChannel,type=Cisco CTI Port,id=3,state=IN_USE,pendingState=null,groupId=11,locked=false]
13842759: Aug 07 07:08:45.717 COT %MIVR-CHANNEL_MGR-7-UNK:ChStubImpl:getChannelLock() -id=4 trying to get channel lock ...
13842760: Aug 07 07:08:45.717 COT %MIVR-CHANNEL_MGR-7-UNK:ChStubImpl:getChannelLock() - Could not get channel lock-ChannelStub[channelClass=com.cisco.call.CallControlChannel,type=Cisco CTI Port,id=4,state=OUT_OF_SERVICE,pendingState=null,groupId=11,locked=false]
13842761: Aug 07 07:08:45.717 COT %MIVR-CHANNEL_MGR-7-UNK:ChStubImpl:getChannelLock() -id=5 trying to get channel lock ...
13842762: Aug 07 07:08:45.717 COT %MIVR-CHANNEL_MGR-7-UNK:ChStubImpl:getChannelLock() - Could not get channel lock-ChannelStub[channelClass=com.cisco.call.CallControlChannel,type=Cisco CTI Port,id=5,state=OUT_OF_SERVICE,pendingState=null,groupId=11,locked=false]
13842763: Aug 07 07:08:45.717 COT %MIVR-CHANNEL_MGR-7-UNK:GroupStubImpl::findAndLockIdleChannel() - returning NULL no channel lock available-GroupStub[channelClass=com.cisco.crs.jtapi.JTAPICallControlChannel,type=Cisco CTI Port,id=11,name=11,state=PARTIAL_SERVICE,channel=5]
13842764: Aug 07 07:08:45.717 COT %MIVR-CHANNEL_MGR-7-UNK:ChStubImpl:releaseChannelLock() - channel lock releasedChannelStub[channelClass=com.cisco.dialog.DialogChannel,type=Cisco Media Channel,id=61,state=IDLE,pendingState=null,groupId=0,locked=false]
13842765: Aug 07 07:08:45.717 COT %MIVR-CHANNEL_MGR-7-UNK:ChMgrImpl:getIdleChannels - There are no idle channels available in group 'Cisco CTI Port Group #11': Exception=com.cisco.lang.sync.AttemptInterruptedException: interrupted while allocating from [(('Cisco Media Channel Group #0' & 'IPCC Express Ports')) & 'Cisco CTI Port Group #11']; nested exception is:
com.cisco.lang.sync.AttemptTimeoutException: timed out allocating from [(('Cisco Media Channel Group #0' & 'IPCC Express Ports')) & 'Cisco CTI Port Group #11']; nested exception is:
com.cisco.lang.sync.AttemptTimeoutException: timed out allocating from ['Cisco CTI Port Group #11']; nested exception is:
13842766: Aug 07 07:08:45.717 COT %MIVR-CHANNEL_MGR-7-EXCEPTION:com.cisco.lang.sync.AttemptInterruptedException: interrupted while allocating from [(('Cisco Media Channel Group #0' & 'IPCC Express Ports')) & 'Cisco CTI Port Group #11']; nested exception is:
13842767: Aug 07 07:08:45.717 COT %MIVR-CHANNEL_MGR-7-EXCEPTION: com.cisco.lang.sync.AttemptTimeoutException: timed out allocating from [(('Cisco Media Channel Group #0' & 'IPCC Express Ports')) & 'Cisco CTI Port Group #11']; nested exception is:
13842768: Aug 07 07:08:45.717 COT %MIVR-CHANNEL_MGR-7-EXCEPTION: com.cisco.lang.sync.AttemptTimeoutException: timed out allocating from ['Cisco CTI Port Group #11']; nested exception is:
13842769: Aug 07 07:08:45.717 COT %MIVR-CHANNEL_MGR-7-EXCEPTION: com.cisco.lang.sync.AttemptTimeoutException: timed out allocating from ['Cisco CTI Port Group #11']; nested exception is:
13842770: Aug 07 07:08:45.717 COT %MIVR-CHANNEL_MGR-7-EXCEPTION: com.cisco.lang.sync.AttemptTimeoutException: timed out allocating from ['Cisco CTI Port Group #11']
13842771: Aug 07 07:08:45.717 COT %MIVR-CHANNEL_MGR-7-EXCEPTION: at com.cisco.lang.sync.MultiSync.attempt(MultiSync.java:401)
13842772: Aug 07 07:08:45.717 COT %MIVR-CHANNEL_MGR-7-EXCEPTION: at com.cisco.lang.sync.PermitCollection.attempt(PermitCollection.java:422)
Aaron Harrison Tue, 08/10/2010 - 01:13
  • Community Spotlight Award,
    Member's Choice, May 2015
As suggested by the other poster; it looks like no media channel is available. In the appadmin web interface on UCCX, go to subsystems/CIsco Media.
Find ''Cisco Media Channel Group #0' ' and see how many channels are assigned to it; it should be at least equal to the number of CTI Ports in 'Cisco CTI Port Group #11' (under subsystems/Unified CM Telephony).
Aaron
c.carrion Tue, 08/10/2010 - 08:42
Hi aaronharrison,
In the  ''Cisco Media Channel Group #0' :Maximum Number Of Channels : 150  and the  'Cisco CTI Port Group #11'  : 10 CTI_Port.
do you have any advise ?
ytang2008 Mon, 02/14/2011 - 06:22
hi carrion,
           I have met the same issue as yours.
          have you found the solution for this case?
look forward your reply. thank you very much.
g-georgiou Mon, 02/21/2011 - 08:43
Hi guys,
I am having the same issue here. Did u manage to solve this?
Thnx
George
ytang2008 Mon, 02/21/2011 - 15:50
hi,
        reload the server it will disappear, but not sure will it happen again.
         i found some infomation,see below
       /* Style Definitions */ table.MsoNormalTable {mso-style-name:普通表格; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman","serif";}
           http://docwiki.cisco.com/wiki/REMOTE_TIMEOUT_-_No_idle_channels
           http://docwiki.cisco.com/wiki/IVR_gets_freezed_when_the_calls_are_more_than_the_actual_ports_and_requires_an_engine_restart_for_recovery
        also check the bug CSCtb77537
        i think it's something wrong with the CTI integration.
g-georgiou Tue, 02/22/2011 - 01:16
Hi Yuan,
Thanks for the prompt reply. It is always nice to see that some else had the same problem
I am running UCCX & UCM v8.02. For some reason under Cisco Media i have 0 channels in the default
dialog group. When i try to call the RP it waits for 4-5 secs and then i get fast busy instead of the call
answered by the CTI ports.
./G
