08-09-2010 05:23 PM
Hi halijenn / experts
I have a query regarding ASA Remote access VPN and want to know as to why ASA is facilitated to configure the IP pools one under tunnel-groups and one under group-policy.Is there any circumstance when one will override the other or is it just an option that VPN pool can be declared under any of them ?
08-10-2010 01:39 AM
the pool in group-policy overrides the tunnel-group pool
http://www.cisco.com/en/US/partner/docs/security/asa/asa82/configuration/guide/vpngrp.html#wp1182747
now i am not sure why the option is given in 2 places, probabaly if someone has multiple tunnel groups and wants to give ip's to all from a set of pools
08-10-2010 04:23 PM
I am not sure if the reason mentioned by you answers my question ; however i am looking for an example as to where it is configured and also an
explanation as to why cisco has introduced this . Can someone please guide me on this
08-10-2010 05:45 PM
The group policy can be selected by certificate attributes or by an authentication server. The group policy can lock users into a specific tunnel group. You can have more than one group policy lock users into the same tunnel group.
You use multiple group policies to change attributes based on the certificate/AAA. If some value, like the pool, does not change for every group policy, you put it in the tunnel group as a default. If you could not do this, you would have to separately enter the pool into each and every group policy.
Here's a simple example:
https://supportforums.cisco.com/docs/DOC-1746
Note this is why you can have three different states for some booleans, e.g.
"re-xauth enable"
"re-xauth disable"
"no re-xauth enable/no re-xauth disable"
These are three different values. The first two override the default, the third allows the default to set the value.
