08-09-2010 05:32 PM - edited 02-21-2020 04:46 PM
If you have the AnyConnect Essentials license for VPN - is the ASA capable of doing any NAC such as checking for registry value or checking is firewall definitions are up to date? Thanks.
Solved! Go to Solution.
08-10-2010 09:35 AM
With an AnyConnect Essentials license enabled, clientless WebVPN, Cisco Secure Desktop (CSD), and Advanced Endpoint Assessment functionality is disabled. Because of this, you will not be able to do registry checks, verify anti-virus updates, etc.
08-10-2010 09:35 AM
08-26-2010 07:07 AM
Unfortunately the AnyConnect Premium license, which allows for this, costs more than 100 times as much as the AnyConnect Essentials license, so it's a non-starter for us.
I would like to pose a simple, basic question: Is there any practical, meaningful way, with an AnyConnect Essentials license, to restrict which client machines can connect? We have no problem with certain users, it's the machines they connect from that may be a problem. We have no problem requiring a human judgement call regarding which clients are suitable. Any ideas?
Has anybody had any luck with using manually issued client certificates for this purpose?
