08-09-2010 08:20 PM - edited 03-16-2019 12:09 AM
Need some help in setting up the system audit logs or alarms/notices to a remote server for monitoring/analyzing purposes.
Using CUCM 7.x cluster.
08-09-2010 10:57 PM
This is frequently asked and you will find good answers. You can use the search tool. Anyway, here is a step by step procedure for setting up audit logs. With a very detailed explanation from William Bell's excellent blog:
http://www.netcraftsmen.net/resources/blogs/audit-logs-on-cucm.html?blogger=William+Bell
http://www.netcraftsmen.net/resources/blogs/audit-logs-on-cucm-part-2.html?blogger=William+Bell
Hope it helps, please rate if it does.
Good luck.
Kind regards,
- Adrian.
08-10-2010 06:47 AM
Thanks Adrian,
I wonder how this is achieved in cucm 6.x ? there is no such option under the tools menu..and the above docs didn't speak anything about it. I've two clusters to manage and need info on the 6.x as well please.
08-10-2010 08:08 AM
In CUCM 6.x you will not find an enhanced audit feature as it exists in CUCM 7.1.2 and later. In CUCM 6.x, it could be awkward and will generate little information.
Anyway, if you want to try in 6.x, you can follow this thread: https://supportforums.cisco.com/message/1159298#1159298
Hope it helps, remember to rate useful posts.
Kind regards,
- Adrian.
