ARMANDO ALVARADO Tue, 08/10/2010 - 05:46
Yes depending on what customization object you created or using the
default. Under port customization pick object go to the customization editor and select
the portal tab on toolbar there should be a mode button to disable or enable. Also try looking
at the navigational panel button also.Hope this helps.
adriansales Thu, 08/12/2010 - 22:07
I already disabled the navigation and the toolbars but it is still there. I attached a file so that you guys can see what I am describing...
Adrian
