Phone line Swap on 7940
Aug 9th, 2010
My customer has got IP phone 7940 configured for two lines first as VOIP and second as PSTN. Now my customer want the first line as PSTN and second line as CUG please let us know is there a way to swap the line only, without the rebat of all the phone.
Lal Mohammad
Jaime Valencia Tue, 08/10/2010 - 06:17
  • Cisco Employee,
  • Hall of Fame,
    2011
You need to explain if this is CUCM/CME and version.
java
lal.mohammad Thu, 08/12/2010 - 01:31
We have got 10,000 ip phone in the cluster, my first line is in VOIP partition and the second line in the PSTN partition both are in different CSS, please let me know how to go about it.
Lal Mohammad.
Jaime Valencia Thu, 08/12/2010 - 09:38
  • Cisco Employee,
  • Hall of Fame,
    2011
You could try this. Create one dummy phone for testing.
Add lines and all config you need.
Use Export all details in BAT on that phone.
Modify the file to switch the DNs.
Delete phone.
Insert new BAT file using all details.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
lal.mohammad Thu, 08/12/2010 - 20:18
Hi Java,
I dont want to do the ReBAT work, as i have different model of phones and ReBAT requires the downtime as we have huge number of phone.
Thanks for your responce
Lal Mohammad.
brendand05 Thu, 08/12/2010 - 21:04
  1. Rename the VOIP partition to PSTN
  2. Rename the PSTN partion to VOIP
  3. Move the route patterns to the correct partitions
  4. Adjust the CSS's to reflect the above changes
lal.mohammad Thu, 08/12/2010 - 21:09
Renaming will not help me as i have got different CSS for differnt phone line contaning multiple partition.
Lal Mohammad
brendand05 Thu, 08/12/2010 - 21:14
The procedure above is what you will need to do.
I would recommend hiring an outside consultant to do the changes for you.
See step 4. for the CSS changes
