How to enable SNMP on GSS-4492-k9
EPHRAIM MANI
Level 3
Level 3
any advice why its not reflecting in the running for startup configuration
snmp-server community-string Test
snmp-server host 1.1.1.1
Thanks for any clue
~EM
so you will probably want to upgrade to 3.1.1 or 3.1.2
8 Replies 8
litrenta
Level 3
Level 3
did you configure "snmp-server enable" prior to trying to configure these lines ? GSS won't take any snmp config unless you do.
Hi litrenta
, SNMP is enabled
ian.richards
I had a similar issue that turned out to be software versions. I can't remember what version we where on 3.x, but I upgraded to 3.1(1) and snmp works fine. A "sh snmp" didn't return any output (or maybe just that it's enabled) where as now I get screens worth.
correct the bug was http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsz70369
you will run into it with 3.1.0 fixed in 3.1.1. Are you running 3.1.0 ?
Yes litrenta
  currently we have Version 3.1(0)
Thanks litrenta , Thats already  in process. will close out this discussion when done.
Thanks for ur advice
upgraded the software version from Version 3.1(0) to Version 3.1(2).
The isssue of SNMP got resolved after the upgrade
