Nuisance Caller.
Aug 10th, 2010
We have a nuisance caller which we would like to block. We have Call Manager 7 and we would like to block this caller from ringing into us.
For example, nuisance caller has a number of 1234567890 and they dial a direct dial number 0987654321. The DDI call comes in on our PRA installed on a Cisco IOS Software, 3800 Software (C3825-ADVIPSERVICESK9-M), Version 12.4(15)T7, RELEASE SOFTWARE (fc3)
I have tried instances when the dial-peer is setup with only destination-pattern 1234567890 and only incoming called-number 1234567890 and still no luck. The caller seems to match on voice translation-rule 1 and sends the caller through.
I setup the following:
voice translation-rule 202
rule 1 reject /1234567890/
voice translation-profile BLOCK_INCOMING
translate calling 202
dial-peer voice 202 voip
description ### Blocking Incoming Call ###
call-block translation-profile incoming BLOCK_INCOMING
call-block disconnect-cause incoming user-busy
rule 1 /9976/ /79216/
rule 2 /9935/ /61635/
rule 3 /990/ /7827/
rule 4 /991/ /7927/
rule 5 /9920/ /58885/
rule 10 /..../ /79116/
HQ_RTR(config)#do sh isdn act
                                ISDN ACTIVE CALLS
Call    Calling      Called       Remote  Seconds Seconds Seconds Charges
Type    Number       Number       Name    Used    Left    Idle    Units/Currency
In    1234567890        4321                    10       0       0
HQ_RTR#
Aug 10 07:31:19.735: ISDN Se0/2/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0034
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Calling Party Number i = 0x2183, '1234567890'
                Plan:ISDN, Type:National
        Called Party Number i = 0x81, 4321'
                Plan:ISDN, Type:Unknown
Aug 10 07:31:20.761: ISDN Se0/2/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x8034
Aug 10 07:31:20.761: ISDN Se0/2/0:15 Q931: TX -> CONNECT pd = 8  callref = 0x8034
Aug 10 07:31:20.773: ISDN Se0/2/0:15 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x0034
HQ_RTR#
Aug 10 2010 08:31:20.777: %ISDN-6-CONNECT: Interface Serial0/2/0:0 is now connected to 1234567890 N/A
HQ_RTR#
Aug 10 2010 08:31:26.786: %ISDN-6-CONNECT: Interface Serial0/2/0:0 is now connected to 1234567890 N/A
Any ideas?
Anthony.
Overall Rating: 3 (2 ratings)
lavanyaps Tue, 08/10/2010 - 03:46
Just try this simple example for blocking specific calling number and revert. Its works in my lab.
Call Blocking Specific Calling Numbers
Configure a voice translation rule to block the desired calling number you want to block. This example uses 9193927393.
 rule 1 reject /9193927393/
!--- Matches the defined number string and rejects the call.
!--- Apply the rule to a translation profile for the calling number.
!--- You could also reject based on called or redirect-called numbers.
voice translation-profile call_block
 translate calling 1
!--- Invokes voice translation rule 1 in order to determine
!--- which calls to reject based on the calling number.
!--- Include the translation profile within a dial peer definition.
dial-peer voice 100 pots
 call-block translation-profile incoming call_block
!--- Invokes the voice translation profile    call_block   on
!--- inbound POTS calls that match this peer
!--- in order to determine which calls to reject.
 call-block disconnect-cause incoming call-reject
!--- Matches this peer for all inbound POTS calls.
 port 1/1:23
Thanks.. If the link is useful, Pl rate..
Anthony O'Reilly Tue, 08/10/2010 - 05:11
Thansk for your reply.
I created a new dial  peer to double check and dialed in. This is testing on my mobile number 0866785601
dial-peer voice 203  pots
incoming called-number  .
port  0/2/0:15
Aug 10 11:07:52.795:  //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling  Number=866785601, Called Number=79116,  Voice-Interface=0x4721FBA8,
   Timeout=TRUE, Peer  Encap Type=ENCAP_VOICE, Peer Search  Type=PEER_TYPE_VOICE,
   Peer Info  Type=DIALPEER_INFO_SPEECH
   Match  Rule=DP_MATCH_INCOMING_DNIS; Called Number=79116
Aug 10 11:07:52.795:  //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
   Is Incoming=TRUE,  Number Expansion=FALSE
Aug 10 11:07:52.795:  //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=79116,  Expanded String=79116, Calling Number=
   Timeout=TRUE, Is  Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
Aug 10 11:07:52.795:  //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0);  Incoming Dial-peer=1 Is Matched
Aug 10 11:07:52.799:  //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0);  Incoming Dial-peer=2 Is Matched
   Result=Success(0);  Incoming Dial-peer=3 Is Matched
   Result=Success(0);  Incoming Dial-peer=10 Is Matched
   Result=Success(0);  Incoming Dial-peer=101 Is Matched
   Result=Success(0);  Incoming Dial-peer=500 Is Matched
   Result=Success(0);  Incoming Dial-peer=202 Is Matched
Aug 10 11:07:52.799:  //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:[email protected]
Aug 10 11:07:52.799:  //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0)  after DP_MATCH_INCOMING_DNIS; Incoming  Dial-peer=500
Aug 10 11:07:52.799:  //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerSPI:[email protected]
   Calling  Number=866785601, Called Number=79116,  Voice-Interface=0x0,
   Peer Info  Type=DIALPEER_INFO_FAX
Aug 10 11:07:52.799:  //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Timeout=TRUE, Is  Incoming=TRUE, Peer Info Type=DIALPEER_INFO_FAX
    OutboundSearch=FALSE, Peer Info Type=DIALPEER_INFO_FAX, Current Peer(Tag=1,Peer  Info Type=DIALPEER_INFO_SPEECH)
    OutboundSearch=FALSE, Peer Info Type=DIALPEER_INFO_FAX, Current Peer(Tag=2,Peer  Info Type=DIALPEER_INFO_SPEECH)
    OutboundSearch=FALSE, Peer Info Type=DIALPEER_INFO_FAX, Current Peer(Tag=3,Peer  Info Type=DIALPEER_INFO_SPEECH)
    OutboundSearch=FALSE, Peer Info Type=DIALPEER_INFO_FAX, Current Peer(Tag=10,Peer  Info Type=DIALPEER_INFO_SPEECH)
    OutboundSearch=FALSE, Peer Info Type=DIALPEER_INFO_FAX, Current Peer(Tag=24,Peer  Info Type=DIALPEER_INFO_SPEECH)
    OutboundSearch=FALSE, Peer Info Type=DIALPEER_INFO_FAX, Current Peer(Tag=4,Peer  Info Type=DIALPEER_INFO_SPEECH)
    OutboundSearch=FALSE, Peer Info Type=DIALPEER_INFO_FAX, Current  Peer(Tag=100,Peer Info Type=DIALPEER_INFO_SPEECH)
    OutboundSearch=FALSE, Peer Info Type=DIALPEER_INFO_FAX, Current  Peer(Tag=200,Peer Info Type=DIALPEER_INFO_SPEECH)
    OutboundSearch=FALSE, Peer Info Type=DIALPEER_INFO_FAX, Current  Peer(Tag=201,Peer Info Type=DIALPEER_INFO_SPEECH)
    OutboundSearch=FALSE, Peer Info Type=DIALPEER_INFO_FAX, Current  Peer(Tag=101,Peer Info Type=DIALPEER_INFO_SPEECH)
    OutboundSearch=FALSE, Peer Info Type=DIALPEER_INFO_FAX, Current  Peer(Tag=500,Peer Info Type=DIALPEER_INFO_SPEECH)
    OutboundSearch=FALSE, Peer Info Type=DIALPEER_INFO_FAX, Current  Peer(Tag=1000,Peer Info Type=DIALPEER_INFO_SPEECH)
    OutboundSearch=FALSE, Peer Info Type=DIALPEER_INFO_FAX, Current  Peer(Tag=987654,Peer Info  Type=DIALPEER_INFO_SPEECH)
    OutboundSearch=FALSE, Peer Info Type=DIALPEER_INFO_FAX, Current  Peer(Tag=202,Peer Info Type=DIALPEER_INFO_SPEECH)
    OutboundSearch=FALSE, Peer Info Type=DIALPEER_INFO_FAX, Current  Peer(Tag=203,Peer Info Type=DIALPEER_INFO_SPEECH)
    Result=-1
Aug 10 11:07:52.803:  //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:[email protected]
Aug 10 11:07:52.803:  //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Match  Rule=DP_MATCH_ANSWER; Calling Number=866785601
Aug 10 11:07:52.803:  //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=,  Expanded String=, Calling Number=866785601T
Aug 10 11:07:52.803:  //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
    Result=-1
   Match  Rule=DP_MATCH_ORIGINATE; Calling Number=866785601
MODELOFFICE#xxxxxxxxxx/DPM/MatchNextPeer:
Aug 10 11:07:52.807:  //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Aug 10 11:07:52.807:  //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
    Result=-1
Aug 10 11:07:52.807:  //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:[email protected]
Aug 10 11:07:52.807:  //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=NO_MATCH(-1)  After All Match Rules Attempt
Aug 10 11:07:52.807:  //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerSPI:[email protected]
Aug 10 11:07:53.833:  //-1/5AD114AD804D/DPM/dpMatchPeersCore:
   Calling Number=,  Called Number=79116, Peer Info  Type=DIALPEER_INFO_SPEECH
   Match  Rule=DP_MATCH_DEST; Called Number=79116
Aug 10 11:07:53.833:  //-1/5AD114AD804D/DPM/dpMatchCore:
   Timeout=TRUE, Is  Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
Aug 10 11:07:53.833:  //-1/5AD114AD804D/DPM/MatchNextPeer:
   Result=Success(0);  Outgoing Dial-peer=24 Is Matched
   Result=Success(0);  Outgoing Dial-peer=100 Is Matched
   Result=Success(0);  Outgoing Dial-peer=101 Is Matched
   Result=Success(0)  after DP_MATCH_DEST
Aug 10 11:07:53.833:  //-1/5AD114AD804D/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched  Outgoing Dial-peer(s):
     1: Dial-peer  Tag=100
     2: Dial-peer  Tag=101
     3: Dial-peer  Tag=24
Aug 10 2010  12:07:53.845: %ISDN-6-CONNECT: Interface Serial0/2/0:0 is now connected to  866785601 N/A
Aug 10 11:07:53.973:  //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=,  Called Number=866785601, Peer Info  Type=DIALPEER_INFO_SPEECH
   Match  Rule=DP_MATCH_DEST; Called Number=86678560
MODELOFFICE#1
Aug 10 11:07:53.977:  //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial  String=866785601, Expanded String=866785601, Calling  Number=
    Result=-1
Aug 10 11:07:53.977:  //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   No Outgoing  Dial-peer Is Matched; Result=NO_MATCH(-1)
Aug 10 11:07:53.977:  //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
    Result=NO_MATCH(-1)
Aug 10 11:07:53.977:  //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=SUCCESS(0)
     3: Dial-peer  Tag=24
Aug 10 11:07:54.109:  //-1/5AD114AD804D/DPM/dpAssociateIncomingPeerCore:
   Calling  Number=866785601, Called Number=8881189121,  Voice-Interface=0x0,
   Timeout=TRUE, Peer  Encap Type=ENCAP_VOIP, Peer Search  Type=PEER_TYPE_VOICE,
   Match  Rule=DP_MATCH_INCOMING_DNIS; Called  Number=8881189121
Aug 10 11:07:54.109:  //-1/5AD114AD804D/DPM/dpMatchPeertype:
Aug 10 11:07:54.109:  //-1/5AD114AD804D/DPM/dpMatchCore:
   Dial  String=8881189121, Expanded String=8881189121, Calling  Number=
Aug 10 11:07:54.109:  //-1/5AD114AD804D/DPM/MatchNextPeer:
   Result=Success(0);  Incoming Dial-peer=200 Is Matched
Aug 10 11:07:54.113:  //-1/5AD114AD804D/DPM/MatchNextPeer:
Aug 10 11:07:54.113:  //-1/5AD114AD804D/DPM/dpMatchPeertype:[email protected]
Aug 10 11:07:54.113:  //-1/5AD114AD804D/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0)  after DP_MATCH_INCOMING_DNIS; Incoming  Dial-peer=200
Aug 10 11:07:54.113:  //-1/5AD114AD804D/DPM/dpAssociateIncomingPeerSPI:[email protected]
Aug 10 11:07:54.113:  //-1/5AD114AD804D/DPM/dpMatchCore:
Aug 10 11:07:54.117:  //-1/5AD114AD804D/DPM/MatchNextPeer:
Aug 10 11:07:54.117:  //-1/5AD114AD804D/DPM/dpMatchPeertype:[email protected]
Aug 10 11:07:54.117:  //-1/5AD114AD804D/DPM/dpAssociateIncomingPeerCore:
Aug 10 11:07:54.117:  //-1/5AD114AD804D/DPM/dpAssociateIncomingPeerSPI:[email protected]
Aug 10 11:07:54.153:  //-1/5AD114AD804D/DPM/dpAssociateIncomingPeerCore:
MODELOFFICE#e=0x0,
Aug 10 11:07:54.153:  //-1/5AD114AD804D/DPM/dpMatchPeertype:
Aug 10 11:07:54.153:  //-1/5AD114AD804D/DPM/dpMatchCore:
MODELOFFICE#eer Info  Type=DIALPEER_INFO_SPEECH
Aug 10 11:07:54.153:  //-1/5AD114AD804D/DPM/MatchNextPeer:
Aug 10 11:07:54.157:  //-1/5AD114AD804D/DPM/MatchNextPeer:
Aug 10 11:07:54.157:  //-1/5AD114AD804D/DPM/dpMatchPeertype:[email protected]
Aug 10 11:07:54.157:  //-1/5AD114AD804D/DPM/dpAssociateIncomingPeerCore:
Aug 10  11:07
MODELOFFICE#:54.157:  //-1/5AD114AD804D/DPM/dpAssociateIncomingPeerSPI:[email protected]
Aug 10 11:07:56.898:  //-1/5AD114AD804D/DPM/dpMatchPeersCore:
   Calling Number=,  Called Number=987654, Peer Info  Type=DIALPEER_INFO_SPEECH
   Match  Rule=DP_MATCH_DEST; Called Number=987654
Aug 10 11:07:56.898:  //-1/5AD114AD804D/DPM/dpMatchCore:
   Dial String=987654,  Expanded String=987654, Calling Number=
    Result=-1
Aug 10 11:07:56.898:  //-1/5AD114AD804D/DPM/dpMatchPeersMoreArg:
    Result=NO_MATCH(-1)
MODELOFFICE#
Aug 10 11:07:59.802:  //-1/5AD114AD804D/DPM/dpMatchPeersCore:
Aug 10 11:07:59.802:  //-1/5AD114AD804D/DPM/dpMatchCore:
    Result=-1
Aug 10 11:07:59.802:  //-1/5AD114AD804D/DPM/dpMatchPeersMoreArg:
    Result=NO_MATCH(-1)
MODELOFFICE#
Aug 10 2010  12:07:59.847: %ISDN-6-CONNECT: Interface Serial0/2/0:0 is now connected to  866785601 N/A
Aug 10 2010  12:07:59.847: %ISDN-6-DISCONNECT: Interface Serial0/2/0:0  disconnected from  866785601 , call lasted 5 seconds
MODELOFFICE#
Dial Peers 100, 101, and  24
dial-peer voice 24  voip
preference 1
destination-pattern  [2347]...
voice-class codec  1
session target  ipv4:x.x.x.x
dtmf-relay  h245-alphanumeric
no vad
dial-peer voice 100  voip
description Dialpeer for  IPCC
translation-profile incoming  block
destination-pattern  7[8-9]...
progress_ind setup enable  3
progress_ind alert enable  8
progress_ind progress enable  8
progress_ind connect enable  8
voice-class codec  1
session target  ras
tech-prefix  2#
dtmf-relay rtp-nte h245-signal  h245-alphanumeric
fax protocol t38 ls-redundancy 0  hs-redundancy 0 fallback none
icpif 25
no vad
dial-peer voice 101  voip
description Dialpeer for SRST 79116 to  61600
translation-profile outgoing  SRST
preference 10
destination-pattern  79...
modem passthrough nse codec  g711ulaw
voice-class codec  1
voice-class h323  1
no vad
I can still get through to the site, it is matching on voice translation-rule 1, rule 10.
rule 3 /990/ /7827/
rule 4 /991/ /7927/
Thanks for you help on this.
Anthony.
lavanyaps Tue, 08/10/2010 - 06:10
Can see multiple Dial-peers and translation rules.. just try this out with one dial-peer and rules for testing.. this works
for me..
WIth the same translation rule, use debug voice translation and then run the test voice translation-rule command again,
to check whether the rules and translations are working or not.
test voice translation-rule 1 77771234
Thanks.
Anthony O'Reilly Tue, 08/10/2010 - 08:07
I did this and it looks like all calls to this router are matched on translation-rule 1
I have a voice translation-rule 202 to block calls from my mobile.
What I was thinking was it wwould be matched with my dial-peer 202 and this will call translation profile INCOMING_BLOCKING which reference voice translation-rule 202.
HQ_RTR#test voice translation-rule 1 0866785601
Matched with rule 10
Original number: 0866785601     Translated number: 79116785601
Original number type: none      Translated number type: none
Original number plan: none      Translated number plan: none
HQ_RTR#test voice translation-rule 202  0866785601
0866785601 blocked on rule 1
HQ_RTR#
Thanks for your help on this one.
Anthony.
lavanyaps Tue, 08/10/2010 - 22:42
I hope the translation profile 202 works for you now.. still if you have problem in blocking the call, pl revert...
If you find the information helpful, pl rate..  thanks..
Anthony O'Reilly Wed, 08/11/2010 - 00:16
Hi lavanyaps
What I was trying to say in my last message was that the call get matches on voice translation-rule 1 on rule 10 and then my test call rings into the office.
In the debug on the dial peers it matches dial-peers
Result=SUCCESS(0)
     3: Dial-peer  Tag=24
It doesn't seem to be matched on my dialpeer 202. It look like it is matches higher up.
Anthony.
Tracy Larson Wed, 08/11/2010 - 07:30
Like the others have stated, you need one inbound dialpeer that calls can match on. Within that specific dial-peer only, apply your blocking profile.
lavanyaps Thu, 08/12/2010 - 00:58
Try to test it in your lab setup with one inbound and outbound dial-peer.. Dial peers works with most specific match and
hence multiple dial-peers will creates complications.. Thanks.
