08-10-2010 02:45 AM - edited 03-04-2019 09:22 AM
Hi there,
Cisco documents shown that Cisco 3845 able to support HWIC-1FE with certain minimum IOS version, but why when I slot in the card, its show the following??? Thanks for the help.
WIC Slot 0:
Unknown WAN daughter card
WIC module not supported/disabled in this slot
Hardware Revision : 2.0
Top Assy. Part Number : 800-27737-02
Part Number : 73-10676-02
Board Revision : B0
Deviation Number : 0
Fab Version : 02
PCB Serial Number : FOC1428365G
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Product (FRU) Number : HWIC-1FE
Version Identifier : V01
CLEI Code : COUIAFTCAA
Base MAC Address : d0d0.fd5e.e135
MAC Address block size : 1
Connector Type : 01
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 05 3A 41 02 00 C0 46 03 20 00 6C 59 02
0x10: 82 49 29 B4 02 42 42 30 88 00 00 00 00 02 02 C1
0x20: 8B 46 4F 43 31 34 32 38 33 36 35 47 03 00 81 00
0x30: 00 00 00 04 00 CB 92 48 57 49 43 2D 31 46 45 20
0x40: 20 20 20 20 20 20 20 20 20 89 56 30 31 20 D9 02
0x50: 40 C1 C6 8A 43 4F 55 49 41 46 54 43 41 41 CF 06
0x60: D0 D0 FD 5E E1 35 43 00 01 05 01 FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Solved! Go to Solution.
08-10-2010 05:46 AM
What version of IOS are you running?
08-10-2010 05:46 AM
08-10-2010 06:16 AM
Hi there,
I tested with 2 IOS, "c3845-ipbase-mz.124-17b.bin" and "c3845-advipservicesk9-mz.124-25b.bin", both show the same result.
regards,
joe
08-10-2010 07:22 AM
Joe
I don't know whether this has been resolved as it is marked as resolved but you need a minimum of 12.4T and you have 12.4 so you need to upgrade the IOS, see Table 1A in this link -
Jon
08-10-2010 07:35 PM
Hi Jon,
You are right, the module only able to detect with IOS release T, others IOS not able to work. thanks for your great support.
regards,
joe
