singe device to single AP config - advice plse
Aug 10th, 2010
Good day everyone.
I have a 4400 series with a lots of access points. I have some specialist devices that become problematic if they roam, and they are not too configurable.
I have been tasked with setting the system up so that the devices are "fixed " to a single AP. so device 1 stays with AP1, device 2 with AP 2, etc.
What would be the most efficient and practical way to achieve this ?
Many thanks for the help.
NM
Leo Laohoo Tue, 08/10/2010 - 14:59
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Give them a specific SSID and configure the access point into an AP group.
Chris Illsley Wed, 08/11/2010 - 09:15
  • Bronze, 100 points or more
Depending on the operating system and whatever wireless supplicant you're using you should be able to hard code the mac address of the SSID too.
Chris
neilmac Thu, 08/12/2010 - 00:56
The client devices are nt configurable, it's not an option.
I have now set up access point groups, and allocated each access point to an access point group.
However, it seems that the access points are broadcasting all SSID's., which isn't solving anything.
I need for example:
AP 1: SSID 1, 2, 3
AP 2: SSID 1, 2, 4
AP 3: SSID 1, 2, 5
etc.
So I made:
group 1, with SSID 1,2,3 and made AP1 a member of group 1.
group 2, with SSID 1,2,4 and made AP2 a member of group 2
group 3, with SSID 1,2,5 and made AP3 a member of group 3.
This way, SSID 1 and 2 should be available everywhere, with SSID 3 only from ap1,  SSID 4 only from ap2, and SSID 5 only from ap3.
So, that's how it's set up, however, all ap's still broadcast ALL ssid's.
What am I missing ?
NM
