Static command doubt
bapatsubodh
If we have following static commends
static (inside,outside) 2.2.2.2    192.168.1.1   (  Public-routable-ip, private-ip)
OR
static (outside,inside)  192.168.1.1 2.2.2.2  ( private-ip,public-routable-ip)
and corresponding permit access-list is configured.  Will these commands will have the same effect.
As there is always one-to-one mapping.
When there is a packet with destination 2.2.2.2 arriving on outside interface  then  it's destination IP address will be replaced by 192.168.1.1 and
packet will be forwarded to that host from inside interface.
In second static
Now, if packet source is 192.168.1.1 and  destination can be anything then while packet is exiting the outside interface then it's source ip address will
be over written by 2.2.2.2 and then packet is forwarded to outside world.
is this understanding correct?
Appreciate you help.
Subodh
2 Accepted Solutions
Kureli Sankar
If the source of the packet is 2.2.2.2 its source will be changed to 192.168.1.1 when it enters the inside interface.
-KS
mirober2
Kureli beat me to it--please disregard
Hi Subodh,
In the scenario you describe, you will want to configure the first static statement (and the corresponding access rules):
The second line you mentioned would only be used if you wanted to do what is called "outside NAT". With that line, users on the inside would see 2.2.2.2 as an internal IP address, 192.168.1.1.
Hope that helps.
-Mike
Kureli Sankar
-KS
mirober2
Hi Subodh,
Hope that helps.
-Mike
