WAE output a mess report
Aug 10th, 2010
hi all
when I show stat con in WAE command line
it outputs a mess report
I use secureCRT and putty are the same
has anyone encountered this problems ?
thanks
like this
Core-WAE#sh stat con               PT No Peer        --More--
Current Active Optimized Flows:                      1527
   Current Active Optimized TCP Plus Flows:          1399
   Current Active Optimized TCP Only Flows:          128
   Current Active Optimized TCP Preposition Flows:   0
Current Active Auto-Discovery Flows:                 141
Current Reserved Flows:                              100
Current Active Pass-Through Flows:                   110
Historical Flows:                                    654
D:DRE,L:LZ,T:TCP Optimization RR:Total Reduction Ratio
A:AOIM,C:CIFS,E:EPM,G:GENERIC,H:HTTP,M:MAPI,N:NFS,S:SSL,V:VIDEO
ConnID        Source IP:Port          Dest IP:Port            PeerID Accel RR   131085   10.102.254.233:4709     10.3.203.210:1352 00:1e:7a:80:ba:af TDL   87.8%917527     10.2.206.210:1960   10.102.254.234:1352 00:16:9d:39:50:ad TDL   76.3%720975     10.6.213.210:1933   10.102.254.234:1352 00:16:9d:39:50:e5 TDL   71.9%983123      10.7.13.210:4599   10.102.254.234:1352 00:21:55:86:3a:25 TDL   69.3%131170   10.102.254.233:4715    192.168.5.210:1352 00:21:5e:57:f3:a0 TDL   87.3%917610     10.3.207.210:4799   10.102.254.234:1352 00:21:55:86:3b:73 TDL   76.4%917626     10.3.207.210:4801   10.102.25262267      10.6.213.12:1866    10.102.254.69:3120 00:16:9d:39:50:e5 T     00.0%131216   10.102.254.233:4716      10.2.10.210:1352 00:21:55:86:39:f3 TDL   88.2%917671     10.3.215.210:2658   10.102.254.234:1352 00:1e:7a:80:ba:bd TDL   75.3%917674     10.3.215.210:2659   10.102.254.234:1352 00:1e:7a:80:ba:bd TDL   73.7%917694     10.2.238.210:1312   10.102.254.234:1352 00:1e:7a:80:ba:5b TDL   74.1%917695     10.2.235.210:1580   10.102.254.234:1352 00:21:55:86:3b:db TDL   76.2%917712     10.2.235.210:1582   10.102.254.234:1352 00:21:55:86:3b:db TDL   75.7%917729     10.2.238.210:1315   10.102.254.234:1352 00:1e:7a:80:ba:5b TDL   76.8%983313        10.2.8.12:1126    10.102.254.69:3100 00:16:9d:39:51:29 TDL   54.4%131354     10.3.236.210:2474   10.102.254.234:1352 00:16:9d:39:50:db TDL   74.4%262487      10.4.28.210:1903   10.102.254.234:1352 00:16:9d:39:51:1d TDL   65.4%786835   10.102.254.38:63203      10.98.91.12:8101 00:21:5e:57:f3:a0 TDL   72.6%131487   10.102.254.233:4720      10.2.42.210:1352 00:21:55:86:3b:af TDL   88.1%328153      10.2.67.210:1984   10.102.254.234:1352 00:1e:7a:80:b4:e1 TDL   71.4%131571     10.2.231.210:1597   10.102.254.234:1352 00:21:55:86:3b:99 TDL   76.3%131606   10.102.254.233:4722      10.2.55.210:1352 00:21:55:86:3a:ef TDL   88.4%393810      10.2.12.104:1743   10.102.254.200:1352 00:21:55:86:3b:83 TDL   86.3%131673   10.102.254.233:4723      10.5.63.210:1352 00:16:9d:39:51:11 TDL   88.5%   613      10.21.79.12:4666    10.102.254.69:3120 00:16:9d:39:50:a3 T     00.0%131686      10.3.26.210:1361   10.102.254.234:1352 00:21:55:86:3b:81 TDL   75.7%656000     10.7.116.210:1059   10.102.254.234:1352 00:16:9d:39:51:27 TDL   73.0%131794   10.102.254.233:4729     10.4.214.210:1352 00:16:9d:39:51:2d TDL
pdinapoli Tue, 08/10/2010 - 09:53
I also use SecureCRT as my terminal program and I've never seen anything like that.
XXXXXX7341#show stat connection
Current Active Optimized Flows:                      3240
Current Active Optimized TCP Plus Flows:          2699
Current Active Optimized TCP Only Flows:          588
Current Active Auto-Discovery Flows:                 89
Current Reserved Flows:                              91
Current Active Pass-Through Flows:                   2687
Historical Flows:                                    602
    51     10.26.30.188:2752       10.26.32.42:445 00:21:5e:54:bb:94 TCDL  73.3%
786493       10.22.1.46:1156        10.32.0.42:445 00:23:7d:07:4a:14 TCDL  77.7%
983146      10.26.80.75:1125        10.32.0.42:445 00:23:7d:06:4e:50 TCDL  71.2%
327828    10.26.102.161:1118        10.32.0.43:445 00:23:7d:06:4e:40 TCDL  76.5%
917678      10.27.28.52:1322        10.32.0.42:445 00:23:7d:07:1e:28 TCDL  71.2%
983275    10.26.166.67:49252        10.32.0.42:445 00:1e:7a:80:cb:cd TCDL  73.1%
852203    10.26.153.129:1143        10.32.0.42:445 00:14:5e:85:5c:0f TCDL  70.4%
787043      10.33.0.136:4781      10.26.32.35:1134 00:23:7d:07:4a:6c TMDL  77.7%
Take a look at your line wrap settings for your default settings in Secure CRT maybe?
