restrict SSID/VLAN to certain AP's ?
Answered Question
Aug 10th, 2010
Is it possible to restrict SSID/VLANS to certain access points from a 4400 controller ?
If I set up new SSID's they are broadcast from all ap's by default, however I onluy want the SSID's to be used in the areas that match the user type.
How do you do this ?
Correct Answer by dancampb about 6 years 2 months ago
Overall Rating: 5 (1 ratings)
neilmac Tue, 08/10/2010 - 07:22
I have multiple SSID's and a singe site, not singel SSID and geographically diverse which is what the groups config does.
Thats not it at all.
neilmac Wed, 08/11/2010 - 05:26
Sorry, you were right.
The technote isn't too clear, but after research and testing, it is the right thing. Thanks for the help.
