SPAN or RSPAN Configuration for intermediate Switch.
Aug 10th, 2010
I am having three switches. My Sniffer is connected with my Core Switche port 11.
I am having 1 core SW, 2 Access SW.
CoreSW --------------Trunk--------------->AccessSw1-----------------Trunk-------------------------AccessSw2.
I am trying to configure Monitor session between AccessSW2 and Core SW.
my configuration ar Core SW
monitor session 1 destination interface Fa0/11
monitor session 1 source remote vlan 901
At AssessSw2
monitor session 1 source interface Fa0/1 - 22
monitor session 1 destination remote vlan 901
these configurations work fine if I ommit AccessSw1.
So what Configuration I need at AccessSW1 to communicate fine. Please help me on this..
Jon Marshall Tue, 08/10/2010 - 07:16
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Have you created vlan 901 on access switch 1 ?
Jon
Md. Sultan Al Arif Tue, 08/10/2010 - 09:37
no . I did not creat any Vlan 901. If I need to creat then should it be remote Vlan or not?
Do I need to add monitor session command there?
Jon Marshall Tue, 08/10/2010 - 09:38
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
You need vlan 901 on all intermediate switches so just add the vlan to the vlan database ie.
access1(config)# vlan 901 name v901
you don't need to configure any monitor commands on the intermediate switch.
Jon
Alexander Rikmanis Mon, 01/27/2014 - 12:59
bumping up the old post, however - do we need to specify a vlan 901 as remote-vlan  on SW2?
Or just creating vlan901 should be enough?
What would happen if we add "remote-vlan" command into vlan901 config os SW2?
Thanks.
Ankur Arora Mon, 01/27/2014 - 13:36
  • Bronze, 100 points or more
Alexander,
You will have to specify the remote vlan on Sw2, just creating it won't help. Following is the config for the SW2.
Switch(config)# monitor session 1 source remote vlan 901
Switch(config)# monitor session 1 destination interface fastEthernet0/5
The commands are a bit platform specific, as they are a bit different for the 6500 switches:
For SW2 on Cisco6500
Router(config)# monitor session 1 type rspan-destination
Router(config-rspan-dst)# source remote vlan 2
Router(config-rspan-dst)# destination interface gigabitethernet 1/2
Ankur
"Please rate the post if found useful"
