Unity 7.x: When can I run ADSchemaSetup?
Answered Question
Aug 10th, 2010
Unity 4.x -> 7.x Unified Messaging - new Domain, Forest and Exchange Server.
Assuming the Exchange server is in place...
Customer would like to run the Schema extension prior to any portion of the Unity server installation.  Can this be done?
The situation is thus:
- Satellite Company has been running it's own Windows Domain, Forest, Unity 4.x, Exchange 2k3, etc.
- Parent Company is bringing the Satellite Company on to it's own Domain, but the Satellite Company is upgrading CUCM, Unity (new Server 7.x), Exchange 2k7 (new Server).
- Parent Company wants to have the Schema Extension done to "their" A/D prior to the Satellite Company installation of the new Unity Server
- Parent Company is in another country with maintenance windows out of sync with Satellite Company
- Patent Company does not wish to grant Schema Admin rights to Satellite Company personal - or Consultants.
So, can I ship them a copy of the DVD, and can they run ADSchema setup prior to me even powering up the Unity Platform Config?  The new Exchange server should already be installed.
Please go easy, I am not an A/D expert by any stretch - I usually just stick to the script 'cause Unity and me struggles
Ta.
-Robert
Correct Answer by Aaron Harrison about 6 years 5 months ago
Yes - we do this on quite a few installs.
The only tricky thing is if you try to save time by not using the DVD there are a bunch of files/folders from the DVD you need to bundle up if you are trying to email out the schema update, or if the admin tries copying it to a DC in order to run it. See this if you hit that  : https://supportforums.cisco.com/message/3049762#3049762
Aaron
Please rate helpful posts...
Overall Rating: 5 (2 ratings)
Correct Answer
Aaron Harrison Tue, 08/10/2010 - 07:14
Aaron
r.stockton Tue, 08/10/2010 - 07:22
Thank you.
And thanks for the link on copying the additional files over.  I was wondering about that
-Robert
