vlan.dat nexus
Aug 10th, 2010
Dear Experts,
I need to find the vlan.dat on a Nexus 5020 to copy a new vlan.dat from a vtp server on the Nexus switch. Can you help me, where to find the vlan.dat on a Nexus?
Thanks for your help!
Andreas
Vinh Hoang Sun, 01/09/2011 - 18:08
Version 5.0 support vtp mode server/client
For 7K
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9402/product_bulletin_c25-617240.pdf
For 5K
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/layer2/502_n1_1/Cisco_n5k_layer2_config_gd_rel_502_N1_1_chapter4.html#task_290839420A914AF995A7A3848F52E171
The file vlan.dat is stored on bootflash:
#dir bootflash:
         46    Dec 30 11:51:15 2010  ..tmp-kickstart
         36    Dec 30 11:51:15 2010  ..tmp-system
   25164288    Dec 30 11:51:15 2010  .tmp-kickstart
  156932426    Dec 30 11:51:15 2010  .tmp-system
       3626    Dec 30 12:01:28 2010  assoc_ascii_cnv.log
      49152    Dec 30 11:51:15 2010  lost+found/
       2327    Jan 07 13:35:44 2011  mts.log
   21126144    Jan 09 02:20:30 2010  n5000-uk9-kickstart.4.1.3.N1.1.bin
   25164288    Dec 30 11:14:00 2010  n5000-uk9-kickstart.5.0.2.N2.1.bin
  134362986    Jan 09 02:25:06 2010  n5000-uk9.4.1.3.N1.1.bin
  156932426    Dec 30 11:34:06 2010  n5000-uk9.5.0.2.N2.1.bin
       4096    Jan 01 11:02:51 2005  vdc_2/
       4096    Jan 01 11:02:51 2005  vdc_3/
       4096    Jan 01 11:02:51 2005  vdc_4/
        472    Jan 07 13:36:13 2011  vlan.dat
Usage for bootflash://sup-local
  581996544 bytes used
  301355008 bytes free
  883351552 bytes total
