ASA 5505 AnyConnect config with IOS 8.3
c2innovations
i found on the internet how to activate anyconnect feature on my ASA5505..  I'm not sure about the new no nat configuration with ios 8.3.  After i put that line, i'm able to connect..  i received an IP on .50.x subnet..  but i can't talk with our .0.x network.  i'm also looking for a split tunnel configuration.
Any help appreciate...
here is the command line;
webvpn
! Specify the AnyConnect image to be downloaded by users
svc image disk0:/anyconnect-win-2.4.1012-k9.pkg 1
! Enable AnyConnect access on the outside ASA interface
enable outside
svc enable
exit
! Create a local IP address pool to assign for remote users
ip local pool SSLClientPool 192.168.50.25-192.168.50.50 mask 255.255.255.0
! Configure NAT exemption for traffic between internal LAN and remote users
!access-list NONAT extended permit ip 192.168.5.0 255.255.255.0 192.168.100.0 255.255.255.0
!nat (inside) 0 access-list NONAT
object network InsideVlan0
subnet 192.168.0.0 255.255.255.0
object network RemoteVPN
subnet 192.168.50.0 255.255.255.0
nat (inside,outside) source static InsideVlan0 InsideVlan0 destination static RemoteVPN RemoteVPN
! Create usernames that will use the AnyConnect remote access only
username userA password test123
username userA attributes
service-type remote-access
username userB password test12345
username userB attributes
! Create a group policy with configuration parameters that should be applied to clients (there are two options available here according to the ASA version you are running)
group-policy SSLCLientPolicy internal
group-policy SSLCLientPolicy attributes
dns-server value 192.168.0.16 192.168.0.17
vpn-tunnel-protocol svc
address-pools value SSLClientPool
!OPTION 2
!ASA(config)# group-policy SSLCLientPolicy internal
!ASA(config)# group-policy SSLCLientPolicy attributes
!ASA(config-group-policy)# dns-server value 192.168.0.16 192.168.0.17
!ASA(config-group-policy)# address-pools value SSLClientPool
!ASA(config-group-policy)# webvpn
!ASA(config-group-webvpn))#vpn-tunnel-protocol svc
! Allow the AnyConnect traffic to bypass access lists
sysopt connection permit-vpn
! Create tunnel group profile to define connection parameters
tunnel-group SSLClientProfile type remote-access
tunnel-group SSLClientProfile general-attributes
default-group-policy SSLCLientPolicy
tunnel-group SSLClientProfile webvpn-attributes
group-alias SSLVPNClient enable
webvpn
tunnel-group-list enable
Yudong Wu
Level 7
Level 7
"nat (inside,outside) source static InsideVlan0 InsideVlan0 destination static RemoteVPN RemoteVPN" is correct way to do "no nat" in 8.3 code.
You can find split tunnel example here.
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a0080975e83.shtml
