08-10-2010 10:58 AM
Hello - does anyone know how to get cable modem information from a Cisco UBR7246 using SNMP? I am specifically looking for the modem counter data that I can get when I execute the following command on the CMTS:
show cable modem counters
I want to be able to see cable modem utilization via an SNMP get. I can see DOCSIS power and SNR information using:
.1.3.6.1.2.1.10.127.1.2.2.1
If you can tell me the OID for the counter info I can write a custom MIB to pull the data.
Bill
08-27-2010 02:54 PM
Hi Bill,
Try for inbound packets OID docsIfCmtsServiceInOctets 1.3.6.1.2.1.10.127.1.3.4.1.6
And for outbound packet OID cdxIfCmtsServiceOutOctets 1.3.6.1.4.1.9.9.116.1.1.3.1.1
HTH,
Jack
08-30-2010 02:27 PM
Excellent! I will give it a try, thanks a bunch!
Bill
